Thread Closed
To Beam Or Not To Beam?
Share Thread Thread Tools
Sep10-03, 08:15 AM   #18
Originally posted by FZ+
No. It is just that you miss the point.
That is always a possibility. It's also possible that the word 'you' means different things to you and me (in which case we can't even agree as to the truth of the previous sentence as it includes the word 'you'...)
If there is a copy, it makes no more sense to say "you" and "your copy".
OK, let's look at this from the subject's perspective: if there is a copy, it makes no more sense to say "me" and "my copy". What I don't understand is, why? Why doesn't it make sense for me to say "I've had a hot-dog for lunch" and "my copy had cheeseburger for lunch"? What's nonsensical about those two statements? What's the right way to convey the information that there was a hot-dog-eating event and a cheeseburger-eating event happening at the same time?
I just don't get it!
Instead, you can think of two "you"s. One you goes to the place. The other you stays there. To each of the yous, their experience is particular.
Sure. But what happens to ME? Are you going to say the two me's are the same? That makes no sense at all to me!
An analogy to what you are saying:
Suppose you make a photocopy of a letter. Now, you go and rip up one of the versions of the letter. Because the other letter is not ripped up as well in the same action, you then conclude that the original letter is magical and special and cannot be copied.
That's exactly what I'm saying: the original cannot be copied! If the copy were a true copy, then everything that was true about the original should be true about the copy. Your example makes it clear that a photocopy is not the original. That's why we call it "a copy" after all!
In both cases, you miss the idea that both versions can persue an individual existence after creation, which eliminates the paradox.
You are saying both you and your copy have individuality, and you are saying they are the same person. This doesn't make any sense to me.
If John and Jack are twin brothers, do you believe they are the same person? What's different between twins and the hypothetical scenario of "copying" a person?
In any case, I believe it's quite possible that we don't agree on what is the meaning of terms like "individuality", "self", "truth", and so on. In which case any attempt at rational discussion is bound to end in misunderstanding.
Sep10-03, 05:06 PM   #19
Yes, exactly! That's what I was trying to convey when I posted this. Thanks Amadeus!
Whitestar
Sep10-03, 06:39 PM   #20
FZ+
What is nonsensical is that you have ALREADY assumed, by labelling one as a copy and one as not that the two are imperfect copies. This make it possible for everything that follows to be an invalid, circular argument.
What this highlights is that the paradox derives from your idea of the word "copy", not what is actually copied. If, as you insist what you require is something that is the same, yet is different, it is not possible for anything to fulfill your idea of copy. You can't copy *anything*. And so your very concept of copy itself is meaningless.
What is conventionally held as a good copy are two, individual objects, deriving from the same process (the act of copying) and sharing close to the same properties - to be apparently identical. In that case, there is no paradox. And this is the sort of copying that is done of your body, and hence presumeably of your consciousness.
Sep11-03, 09:34 AM   #21
Not everything but some things. Think about this for a minute: if there's no way to tell one object from another, then we must think of them as the same object. That is known in physics as the Pauli exclusion principle, and that's where you seem to be coming from.
I would agree with you that if an outside observer can't tell the difference between myself and a copy of myself, then the outside observer must think of both me's as the same person. But the problem for your argument is that it doesn't take into account the subjective perspective: even if you think there are two me's, *I* am convinced there is only one. If you see my copy walking down the street and you tell me, "hey, look, that's you down there", I would immediately correct you, "no, that's not me, I am here by your side; what you see there is my copy".
It's not meaningless. I can take a piece of paper and draw a circle of radius X. I can take another piece of paper and copy my first drawing: draw another circle of radius X. Have I made a copy? I sure have. Are both drawings the same? They are not! Even if they look exactly the same, down to the last particle in the piece of paper, they still occupy two different positions in space and time.
From my perspective, the flaw in this "copying a person" scenario is the failure to take into account that you can copy a person's body but you cannot copy the space and time coordinates a person occupies.
I object to the "sharing close to the same properties". You can, at least in principle, copy any object down to every single property except for two: its position in space and time. And since one property of consciousness is that it knows its position in space and time, that means you can't copy a person's consciousness, even if you can copy every single atom of that person's body.
I'm sorry if that argument smacks of souls, spirits, or dualism. I can't do anything about it, it's pure logic as far as I can tell.
Sep11-03, 06:23 PM   #22
FZ+
And the other you will say the same. It is still better to say there are two yous, than presume from the beginning a distinction of you, and your copy.
And so the same for conciousness. But what you have set as an additional factor is that future influences on the circle be shared as well - destroy one circle, and the other is destroyed too. In that case, this idea of copy is not meaningful.
Precisely. And for this precise reason, the sort of copy you make out for the person is meaningless.
But the nature of the universe makes that meaningless, as we cannot establish such an absolute idea of it. It cannot be determined which of the yous holds the original space/time position. It is furthermore clear that position and time are constantly changing, and so illogical that exact knowledge and similarity are maintained in consciousness. When you move, you switch to a new position - and yet your consciousness is not lost.
And hence we return to the waking up analogy - consciousless is a process, not a property. When the consciousness is duplicated, senses bring a new awareness of location and time, and each is none the wiser.
Sep12-03, 08:21 AM   #23
I could agree with you in principle, but I have a problem with the consequences of this kind of reasoning: it eventually leads you to think everyone is the same person.
If "me" and "my copy" are the same person, what stands in our way of saying "me" and "my brother" are the same person? What about "me" and "Elvis Presley"? "me" and "Napoleon Bonaparte"? "me" and "Jesus Christ"? Do you realize the trouble?
If you'd like to go with that, I don't think I have a logical counterargument to offer. The best I can do is write you off as a mystic whose ideas lie beyond my ability to comprehend. But I don't think that is the case, I think we are simply miscommunicating.
Sep12-03, 06:29 PM   #24
FZ+
Ok... I think we are hanging up on the idea of "same". When I talk of making a copy, I mean same in origin from the process that made them. Obviously our consciousness, our "state of mind" is something that is dynamic, constantly changing. Hence it is certain that even if made the same, the consciousness copies would diverge by just natural development. Napoleon as a baby is probably very similar to you or I as a baby - but then we grew up.
Thread Closed
Thread Tools
Similar Threads for: To Beam Or Not To Beam?
Thread Forum Replies
[Vibration analysis] Timoskenko beam Vs.Euler-bernoulli beam ? Mechanical Engineering 2
Do you calculate the amount of load a beam can take based on when the beam cracks? Materials & Chemical Engineering 6
Beam Introductory Physics Homework 3
what size of I-BEAM that i will use to carry a load of 2270Kg? General Engineering 2
beam pde Differential Equations 11
