Register to reply
Limiting Distribution
by stevenham
Tags: distribution, limiting
Share this thread:
stevenham
#1
Oct20-11, 04:55 PM
P: 8
Suppose P(Xn = i) = [itex]\frac{n+i}{3n+6}[/itex], for i=1,2,3.
Find the limiting distribution of Xn
2. Relevant equations
3. The attempt at a solution
I first found the MGF by Expectation(etx)
which resulted in etx([itex]\frac{n+1}{3n+6}[/itex] + [itex]\frac{n+2}{3n+6}[/itex] + [itex]\frac{n+3}{3n+6}[/itex])
I then took the limit as n[itex]\rightarrow[/itex] ∞ which gives me 2etx
Did I do this problem correctly? Is that the limiting distribution of Xn?
Thanks.
Phys.Org News Partner Science news on Phys.org
Bees able to spot which flowers offer best rewards before landing
Classic Lewis Carroll character inspires new ecological model
When cooperation counts: Researchers find sperm benefit from grouping together in mice
Ray Vickson
#2
Oct20-11, 06:03 PM
Sci Advisor
HW Helper
Thanks
P: 4,959
Quote Quote by stevenham View Post
Thanks.
1) What you wrote is not the MGF.
2) You don't need the MGF; in fact, using the MGF is doing it the hard way.
RGV
stevenham
#3
Oct20-11, 08:32 PM
P: 8
Do I have to calculate the CDF?
After calculating the CDF and doing the limit as n goes to infinity, I get 1.
Did I calculate the MGF incorrectly? Should I have done E(e^ti) instead?
Ray Vickson
#4
Oct21-11, 02:15 AM
Sci Advisor
HW Helper
Thanks
P: 4,959
No, you did not calculate the MGF; you calculated exp(tx) times the sum of the probabilities-- in other words, just exp(tx), and for some completely undefined x. Yes, you should have calculated E(exp(t*i)), because that is exactly what the MGF is in this case (except you have used the symbol 'i' instead of 'X'). However, my original statement stands: you don't need the MGF, although using it correctly will do no harm.
RGV
canis89
#5
Oct21-11, 04:22 AM
P: 30
No, you got it wrong. If you want to use the MGF method to find the limiting distribution, then, first, find the MGF of Xn for each n, which is
[itex]MGF_{X_n}(t)=E[e^{tX_n}]=\sum_{k=1}^3 e^{tk}P(X_n=k)[/itex].
Then, find the limit of the MGF as n tends to infinity. Finally, find some random variable X with MGF equal to [itex]\lim_{n\rightarrow\infty}MGF_{X_n}(t)[/itex].
My suggestion is, instead using the MGF method, find the cumulative probability function, Fn(i)=P(Xn<=i) for each i=1,2,3. Then, limit this function as n tends to infinity. The limit is the cumulative probability function of the limiting distribution.
Register to reply
Related Discussions
Limiting value General Math 2
Voltage limiting? Electrical Engineering 6
Determining Limiting Distribution Calculus & Beyond Homework 0
Limiting value of the velocity Introductory Physics Homework 7
Limiting Reactions help Chemistry 4
