angelina
- 9
when talking about conservation of angular momentum of a spinning ice skater, the contact surfaces are assumed to be frictionless. why?
The discussion revolves around the conservation of angular momentum in the context of a spinning ice skater, particularly focusing on the role of friction between the skater's blades and the ice surface.
Participants are actively questioning the assumptions made about friction and its effects on angular momentum. Some have offered insights into how torque from friction influences the system, while others are clarifying the conditions under which angular momentum is conserved.
There are ongoing discussions about the definitions of systems involved (skater alone vs. skater plus ice) and the nature of external torques affecting angular momentum conservation.
angelina said:when talking about conservation of angular momentum of a spinning ice skater, the contact surfaces are assumed to be frictionless. why?
*total* angular momentum means the system of the skater alone or the system of the skater + ice floor?Tide said:A frictionless surface is assumed simply because it's a lot easier to analyze. However, the inclusion of friction does not alter the fact that total angular momentum is conserved.
then my question will become - is it true that as longer as there's external torque, no matter this torque is acting about the same axis as the rotation or about a different axis, angular momentum is not conserved??Doc Al said:If there is friction between the ice and skate, then the ice will apply a torque to the skater, reducing her angular momentum. Of course, if you include both the skater and the ice floor in your system, then angular momentum is conserved.
for the case of the spinning skater, if friction exists, which axis will its torque act about? the same vertical (y-axis) or the z-axis or both??Doc Al said:Right. If there is an net external torque, then total angular momentum is not conserved. But it is often the case that you can conserve angular momentum about a particular axis.
In the case of the spinning skater, her axis of rotation is vertical, and, assuming no friction, there is no torque about that vertical axis. So her angular momentum about that axis is conserved.
