New Reply
Vectors Multiplication
Share Thread
Oct23-11, 02:27 PM   #1
Actually I have two questions
Vectors A and B are shown on the figure below. Which one of the
following statements is correct?
a) A . B = 0 and A × B ≠ 0
b) A . B ≠ 0 and A × B = 0
c) A . B ≠ 0 and A × B ≠ 0
d) A . B = 0 and A × B = 0
Picture: http://i.imgur.com/X0GB9.png
2. Relevant equations
A.B = AxBx + AyBy
3. The attempt at a solution
Obviously, the answer is zero. but the problem is the difference between A . B and A x B. I have long thought that those two are the same, but this question confused me.
I tried google for a bit and found out that [ dot product (u . v) gives a scalar ] and [ cross product (u x v) gives a pseudovector ]. It's my first time hearing about a pseudovector =_=
My second question is also about Vectors Multiplication
A and B are the two vectors shown in the figure. Vector A is along the positive x
axis and has a magnitude of 5 cm, and the vector B is in the x-y plane at an angle 30º
with the positive x axis and has a magnitude of 4 cm. A × B =
a) 20 cm2 in the +x direction b) 10 cm2 in the +y direction
c) 10 cm2 in the +z direction d) 20 cm2 in the -y direction
A.B = AxBx + AyBy
When I tried to solve it I got C= 17.5 + 0, so the answer might be a.
This cm^2 and the +z confused me, so I just wanted to confirm.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Oct23-11, 03:54 PM   #2
Here is a re-fresher on dot and cross product.
http://ltcconline.net/greenl/courses...rs/dotcros.htm
For 2 vectors A and B orthoganol ( at right angles) then the dot product A . B = 0, (ie there is no component of A is the same direction as B ( or visa-versa ) sometimes called the projection of A on B.
But, the other part of the answer is A x B = 0 or A x B ≠ 0.
What is your relevant equation for A x B??
Well, you are multiplying a value in A with dimensions cm by one in B of dimension cm, so that would be cm^2.
Axis x and y make a plane,
Add another axis called z and you can work with volumes.
The axis can also be labelled by the unit vectors i,j,k, which you might not have seen yet.
Oct24-11, 12:42 AM   #3
Quote by 256bits View Post
Thank you for you reply,
Yeah, I understood the first one thanks to the website you posted.
first question answer: a) A . B = 0 and A × B ≠ 0
and the answer for the second one is ' C= 17.5 + 0 '
Thanks (*
New Reply
Similar discussions for: Vectors Multiplication
Thread Forum Replies
Vectors: Given two vectors, find a vector that bisects the angle between the two give Calculus & Beyond Homework 10
Multiplication of Vectors Calculus & Beyond Homework 7
Position Vectors, Velocity Vectors, and Acceleration Vectors Introductory Physics Homework 3
scalar multiplication of two equal vectors Calculus & Beyond Homework 8
Scalar multiplication(vectors) Linear & Abstract Algebra 3
