Extending a uniformly cont function on an open interval to a closed interval?
The discussion revolves around the properties of a uniformly continuous function defined on a bounded open interval and the implications for extending this function to a closed interval. Participants explore the relationship between uniform continuity and boundedness, particularly in the context of the Extreme Value Theorem.
  • The original poster attempts to define the function at the endpoints of the interval to apply the Extreme Value Theorem, questioning the role of uniform continuity in this process.
  • Some participants suggest a simpler approach involving selecting points within the interval that are close to the endpoints, linking this to uniform continuity.
  • Concerns are raised about the nature of the interval being open rather than closed, leading to questions about the definitions and continuity at the endpoints.
  • Further attempts involve defining sequences converging to the endpoints and discussing the implications for the function's boundedness.
Participants note the distinction between open and closed intervals, which affects the definitions and continuity at the endpoints. The original poster expresses uncertainty about the necessity of continuity at the endpoints to apply the Extreme Value Theorem.
moxy
Show that the function [itex]f: J → ℝ[/itex] is bounded if [itex]f[/itex] is uniformly continuous on the bounded interval J.
J is a bounded interval, so say J = (a,b)
[itex]f[/itex] is uniformly continuous on J, so
[itex]\forall \epsilon > 0[/itex] there exists a [itex]\delta > 0[/itex] such that for [itex]s,t \in J = (a,b)[/itex]
[itex]|f(s) - f(t)| < \epsilon[/itex] whenever [itex]|s - t| < \delta[/itex]
[itex]f: J → ℝ[/itex] is bounded if there exists a real number M such that |f(x)| ≤ M for all x in J.
I think that if I can extend [itex]f[/itex] to the endpoints of J, then I can use the Extreme Value Theorem to say that [itex]f[/itex] attains a min and max value, i.e. is bounded. So I need to define [itex]f(a)[/itex] and [itex]f(b)[/itex].
[itex]f(a) = \lim_{n→∞}{f(a + \frac{1}{n})}[/itex]
[itex]f(b) = \lim_{n→∞}{f(b - \frac{1}{n})}[/itex]
Where clearly [itex]f[/itex] is defined on [itex][a + \frac{1}{n}, b - \frac{1}{n}][/itex] for all [itex]n \in ℕ[/itex]
Am I on the right track? I don't feel like I've used the fact that [itex]f[/itex] is uniformly continuous on J. Is it because [itex]f[/itex] is uniformly continuous that I'm able to define [itex]f(a)[/itex] and [itex]f(b)[/itex]?
Try to do this more simply. The idea is to pick x1,...,xn such that every x in J is "close" to one of these xi. This plus uniform continuity will give you what you want.
But I only know that J is bounded, not that it's closed and bounded. So can't I only say that J = (a,b) and not necessarily J = [a,b]? So I don't immediately know if f is defined at a or b, much less if it's continuous at a and b.
Okay, nevermind, you changed your post. So... I should define a sequence of, say, rational numbers {xn}, where all xi are in J, such that [itex]lim_{n->∞}{\{x_n\}} = a[/itex] ?
And similarly, {yn}, where all yi are in J, such that [itex]lim_{n->∞}{\{y_n\}} = b[/itex] ?
I think that I'm able to do this, but I don't see how it gets me any closer to showing that f is bounded.
EDIT:
I guess I can say that
[itex]lim_{n->∞}{f(x_n)} = f(a)[/itex]
[itex]lim_{n->∞}{f(y_n)} = f(b)[/itex]
So f is defined on [a,b]. Do I still have to show it's continuous at a and b to use the extreme value theorem? I don't see how this approach is simpler or much different than the one in my original post.
  • · Replies 20 ·
