Rate of Reaction: Effects of Volume Changes
  • Thread starter Thread starter decamij
    Rate Reaction
The discussion focuses on the effects of volume changes on the reaction rate between potassium iodate (KIO3) and sodium hydrogen sulfite (NaHSO3) at room temperature. Increasing the volume of either reactant generally leads to an increase in the reaction rate due to higher concentrations of reactants. Conversely, decreasing the volume of either reactant is expected to slow the reaction. The use of starch as an indicator can also affect the visibility of the reaction endpoint but does not directly influence the reaction rate itself.
  • Understanding of chemical reaction rates
  • Knowledge of stoichiometry and concentration
  • Familiarity with potassium iodate and sodium hydrogen sulfite reactions
  • Basic laboratory skills for conducting experiments
  • Conduct experiments to observe the effects of varying reactant volumes on reaction rates
  • Research the rate equation for the KIO3 + NaHSO3 reaction
  • Learn about the role of indicators in chemical reactions
  • Study the principles of reaction kinetics and concentration effects
Chemistry students, laboratory technicians, and educators involved in teaching reaction kinetics and experimental design.
decamij
If i were to increase to react potassium iodate with sodium hydrogen sulphite at room temperature, what would happen to the rate of react and why if:
1) i increased the volume of iodate solution added
2) increased the volume of the sodium hydrogen sulhpite solution.
3) used too much starch indicator
4) decreased the volume of iodate solution added
5) decreased the volume of the sodium hydrogen sulhpite solution.
I have a lab due monday and my teacher doesn't teach us a thing! Thanx a bunch!
Strictly speaking, you can not predict the effect of concentration on the reaction rate, and will have to do an experiment to determine this. In most cases, however, you can expect the reaction rate to depend directly on the concentrations of the reactants.
So, is this a question from a lab that you've already done, or for a lab that you are going to do ? The KIO3 + NaHSO3 rection is often used for labs where you are asked to determine the rate equation from the experiments. Is this what the lab is about ? If so, the question must be answered using the results of the lab.
Ya but I'm talking about volume, not concentration. If, for example, i used more sodium hydrogen sulphite, what would happen?
9K
