Finding Displacement with angles and directions
The discussion focuses on calculating the displacement of a dog that runs 24m [W 12° S] and then 33m [E 52° S]. The correct displacement is determined to be 31m [W 84° S]. The participants emphasize the use of the cosine rule and sine rule to find the resultant angle and displacement. A common point of confusion arises from the calculations involving angles and the application of trigonometric functions, particularly when determining the angle between the resultant displacement and the initial direction.
  • Understanding of vector addition in physics
  • Familiarity with trigonometric functions, specifically sine and cosine
  • Knowledge of the sine rule and cosine rule for triangles
  • Ability to interpret directional notation in physics (e.g., [W 12° S])
  • Study the application of the sine rule in vector problems
  • Practice using the cosine rule for calculating resultant vectors
  • Learn how to convert between different directional notations in physics
  • Explore common pitfalls in trigonometric calculations and how to avoid them
Students preparing for physics tests, particularly those focusing on vector addition and displacement calculations, as well as educators seeking to clarify trigonometric applications in physics.
Shanetm
I am having a nightmare doing homework for my physics test. I have figured out part of the answer but can not figure out what the angle of the displacement is and its driving me crazy...
The teacher showed us two methods of how to find the answers, but ended up making an error somehow on the first example which was never resolved, which is the one I am going by making it that much harder since I prefer that method(The other method is the one that you have to find Δd1x and Δd2x then Δd1y and Δd2y and go from there) It seems much simpler and he got the right answer using it vs the method mentioned earlier, but when I tried it the answer I got was even more far off so I clearly don't know where I am going with it. (maybe if someone is able to explain it to me, it would be more effective)
The question I can't figure out is "A dog runs after a ball 24m [W 12° S] and then heads 33m [E 52° S] after being distracted by a squirrel. What is his displacement?
Δd1=24 [W12°S]
Δd2=33 [E52°S]
ΔdT=?
I have drawn the triangle, and labelled its sides, decided the two distances create a 64° angle and so far have managed to find out the displacement is 31 meters by using the formula c^2=a^2+b^2-2abCOSc. My problem is figuring out the correct formula to obtain the angle. I've tried different methods and none of them work. The answer is supposed to be 31m[W84°S] this textbook has been wrong multiple times in the past however. Any help is appreciated as the test is tomorrow and I'm sure this will be on it.
Δd1=24 [W12°S]
Δd2=33 [E52°S]
ΔdT=?
Now that you have all three sides of the triangle, you can use sine rule or cosine rule to find the other angles in the triangle.
You may find that the angle between this resultant displacement and the W12S displacement is , say, 70o.
That means the resultant is 70o more than West 12o S, which would make it W 82o S
If the answer really is W 84o S, then that angle in the triangle must actually be 72o.
Okay, I think I understand now. Since the angles I have to work with are 72° and 12° (d1), the answer would be 84°
I think that sheds a bit of light on things. Thank you Peter. I will definitely make sure I keep this in mind
Edit: I've run into a bit of an issue. I've been using the SIN law and doing the calculation 33SIN64 (Divided by 31) to find the resultant angle and I keep getting 73 and not 72... Arghh
However, If I find 24SIN64 (Divided by 31), I get 44 and then add 33 to it which becomes 84
Im so confused right now )=
Edit again: Okay, I figured this out for good! What I was doing wrong was not leaving the extra decimal places in the equation when dividing my 31. All I had to do was divide by 33.16 which was the answer from before and bang, got my answer. Woot!
-Shane
  • · Replies 0 ·
