New Reply
Lagrange Multipliers to find max/min values
Share Thread Thread Tools
Oct25-11, 03:55 PM   #1
Use Lagange Multipliers to find the max and min values of the function subject to the given constraint(s). f(x,y)=exp(xy) ; constraint: x^3 + y^3 = 16
2. Relevant equations
[itex]\nabla[/itex]f = [itex]\nabla[/itex]g * [itex]\lambda[/itex]
fx = gx * [itex]\lambda[/itex]
fy = gy * [itex]\lambda[/itex]
3. The attempt at a solution
Set the fx and fy eqns equal to 0. but i cant solve for x, y, and lambda... i guess my algebra isnt that strong
i got fx = [itex]\lambda[/itex] * gx
y*exy = 3x2[itex]\lambda[/itex]
and for y:
x*exy = 3y2[itex]\lambda[/itex]
and g(x,y) = x3 + y3 = 16
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Oct25-11, 05:32 PM   #2
no one can offer a little help? =/
Oct25-11, 06:26 PM   #3
Recognitions:
Homework Helper Homework Help
Hi arl146!
You need to solve this set of equations:
(1) y exy = 3x2λ
(2) x exy = 3y2λ
(3) x3 + y3 = 16
Can you find λ from equation (1)?
And also from equation (2)?
Then equate them to each other, effectively eliminating λ?
Oct25-11, 07:41 PM   #4
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Since a specific value for [itex]\lambda[/itex] is not necessary for the solution, I find it is often simplest to start by eliminating [itex]\lambda[/itex] by dividing one equation by another. Here, start by dividing [itex]ye^{xy}= 3x^2\lambda[/itex] by [itex]xe^{xy}= 3y^2\lambda[/itex]: [itex]y/x= x^2/y^2[/itex] which is the same as [itex]x^3= y^3[/itex]. Putting that into [itex]x^3+ y^3= 16[/itex] gives [itex]2x^3= 16[/itex].
Oct26-11, 12:52 AM   #5
well i sorta did something like that and got and y=x and with the whole x^3 + y^3 = 16 that means y=x=2. so theres what, is it called a critical pt still, at (2,2) ? so i just plug that into f(x,y)= exp(xy) ??
so you'd have f(2,2)=exp(4) .... is that all i do ? it just seems wrong.idk why haha
Oct26-11, 01:41 AM   #6
Recognitions:
Yes that's all you do. :)
The only thing remaining is finding out whether it's a maximum or a minimum...
Oct26-11, 01:58 AM   #7
yea i think thats why i came here because i got confused with that one value. how do you know?
Oct26-11, 04:24 AM   #8
Recognitions:
Quote by arl146 View Post
Doesn't your class material cover that?
Anyway, I know of 3 methods:
1. Using the second derivative test (Hessian matrix).
I can't quickly find a easy example for it (yet).
2. Since you only have one extrema, you can pick any point that satisfies the constraint and calculate f(x,y) there. Compare it with the f(x,y) at the extremum and you know whether it's a maximum or a minimum.
3. Vary x with a small epsilon, and calculate how you need to vary y to match the constraint in first order approximation.
In your case (x + epsilon)^3 + (y - epsilon)^3 = 16.
Check what f(x + epsilon, y - epsilon) does relative to f(x,y).
New Reply
Thread Tools
Similar Threads for: Lagrange Multipliers to find max/min values
Thread Forum Replies
Lagrange Multipliers: Minimum and Maximum Values Calculus & Beyond Homework 6
Lagrange to find eigen values and vectors? Calculus & Beyond Homework 4
Lagrange Multipliers Find 3 positive numbers? Calculus & Beyond Homework 1
extreme values (Lagrange multipliers) Calculus & Beyond Homework 5
Lagrange Multipliers - unknown values Calculus & Beyond Homework 2
