Solving integral equation with double ingegrals and singularities
The discussion focuses on solving a complex integral equation involving double integrals and singularities, specifically the equation f(x,y,w) = 137.03*y^2/((0.238*exp(0.067*y^2)+1)*(w-5.26*xy-2.63)*(w-5.26*xy+2.63)) = 1 + 8478/(10828-w^2-1.13*j*w). The user attempts to find the complex variable w using MATLAB's dblquad and fsolve functions. The recommended approach includes a brute-force search in the complex plane, starting with a circle around the origin and iteratively refining the search to minimize the difference between the left-hand side and right-hand side of the equation.
  • Understanding of complex analysis and integral equations
  • Familiarity with MATLAB programming, specifically the dblquad and fsolve functions
  • Knowledge of numerical methods for solving equations
  • Basic concepts of singularities in mathematical functions
  • Research numerical methods for complex root finding
  • Learn about MATLAB's optimization toolbox for advanced solving techniques
  • Explore the concept of singularities and their impact on integral equations
  • Investigate alternative numerical integration methods beyond dblquad
Mathematicians, engineers, and researchers dealing with complex integral equations, particularly those utilizing MATLAB for numerical analysis and optimization.
srabbaa66
Hello
I need help to solve the following integral equation:
f(x,y,w)=137.03.*y.^2./((0.238.*exp(0.067.*y.^2)+1).*(w-5.26.*x.*y-2.63).*(w-5.26.*x.*y+2.63))=1+8478./(10828-w.^2-1.13.*j.*w)
xmin=-1, xmax.=1, ymin=0, ymax=inf (nad can be taken 500 because the function decreases rapidly)
I want to find w which is complex number.
I tried the following code:
f=@(w) dblquad(@(x,y) 137.03.*y.^2./((0.238.*exp(0.067.*y.^2)+1).*(w-5.26.*y.*x-2.63).*(w-5.26.*y.*x+2.63)),-1,1,0,100)-1-8478./(10828-w.^2-j.*w.*1.13)
V=fsolve(f,160)
There are some singularities. How can I solve the problem
Looks like you have:
[tex]g(w)=\int\int f(w,x,y)dxdy[/tex]
for complex w. Then unless someone can suggest an analytical approach, I would recommend a brute-force search in the complex plane for w. Start with a circle about the origin. Say 100 points around it. Compute both sides. Find the minimum absolute value of the difference between the RHS and LHS. That the current point. Now take a small circle around that point, another 100 points, find the minimum again. Keep doing this and I think the trajectory will lead to the solution unless some problems are encountered.
  • · Replies 20 ·
