New Reply
mass distribution and gravitational field
Share Thread Thread Tools
Oct27-11, 07:20 AM   #1
The field outside a body with spherical mass distribution is well known but for a non simmetrical body (or a almost simmetrical body like the earth) which is the approach?. Do you know any reference?
thank you
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Oct27-11, 08:41 AM   #2
I think you can apply Gauss law. You can draw a spherical surface with center of center of mass of the object. When the sphere includes all the masses, according to gauss law, it is the same. Since Gauss theorem ▽·g=4πGρ, and apply the law ∫▽·g dV=∫g·dσ=4πM, where M is the mass inside the sphere. Therefore on this occasion where it is sufficiently far from the center of the object, you can use Newton.
Oct27-11, 09:44 AM   #3
Newton's law of gravity in its familiar form gives the gravitational force between two point mass objects (or two uniform spheres which act as point objects). However, it can be cast in a form that handles non-spherical masses. Just treat a non-spherical mass as a collection of integration volumes, each behaving as a point mass, and integrate over the volume.
Newton's Law in full fixed-coordinate vector form:
F= - G m m' (x - x')/|x - x'|3
where F is the gravitational force of mass m' on m located at x' and x respectively. If another massive body m'' is introduced, it's force on m is just additive:
F= - G m m' (x - x')/|x - x'|3 - G m m'' (x - x'')/|x - x''|3
If we bring many point masses into the picture, we just add up all the forces:
F= - G m Ʃ mi(x - xi)/|x - xi|3
In the limit that the point masses get so packed together that they can be treated as constituting a spatial continuum of mass, the sum becomes a volume integral:
F= - G m ρ(x')(x - x')/|x - x'|3 d(3) x'
where ρ is the mass density. This is what you would use for extended non-spherical mass objects.
Oct27-11, 01:43 PM   #4
You can also use Poisson's equation for the gravitational potential.
Oct29-11, 10:08 AM   #5
Thank you,
questions:
what effects on the general motion of the earth are due to its non-spherical symmetry?
astrophysicists will take account of this....
Even artificial satellites are definitely not spherically symmetric objects (although relatively small): as we can account for this?
Oct29-11, 11:33 AM   #6
Quote by DrStupid View Post
In my mind the easiest way ...
Dec31-12, 10:22 AM   #7
I return to the topic after a long time ...
A tangible example, the moon will not be a celestial body in perfect spherical symmetry. How this affect on its motion around the earth?
thanks
New Reply
Thread Tools
Similar Threads for: mass distribution and gravitational field
Thread Forum Replies
Optimal mass distribution for maximal gravitational field Advanced Physics Homework 0
Symmetry of mass distribution producing radial gravitational force field Classical Physics 11
Gravitational field has mass??? Special & General Relativity 5
the Higgs field: so gravitational field by itself cannot confer mass? High Energy, Nuclear, Particle Physics 4
Equilibrium temperature distribution of ideal gas in homogeneous gravitational field Classical Physics 4
