Commuting derivative/Integral (not FTC or Leibniz)
  • Context: Graduate
  • Thread starter Thread starter nickthequick
    Leibniz
This discussion focuses on deriving the Euler-Lagrange equations for slowly modulated surface gravity waves using an averaged Lagrangian defined as \(\mathcal{L}=\frac{1}{2\pi}\int_0^{2\pi}Ld\theta\). The variables \(\theta_x=k\) and \(\theta_t=-\omega\) represent wave number and frequency, respectively. The primary equation under consideration is \(\frac{\partial L}{\partial \theta}-\frac{\partial }{\partial x }\frac{\partial L}{\partial \theta_x}-\frac{\partial }{\partial t}\frac{\partial L}{\partial \theta_t}=0\). The discussion reveals that while the first term of the integrated equation vanishes due to periodicity, the relationship between the averaged Lagrangian and the second derivatives remains complex and requires further assumptions about the periodicity of \(L\) and its derivatives.
  • Understanding of Euler-Lagrange equations
  • Familiarity with Lagrangian mechanics
  • Knowledge of periodic functions and their properties
  • Basic concepts of wave mechanics, including wave number and frequency
  • Study the derivation of the Euler-Lagrange equations in detail
  • Explore the implications of periodicity in Lagrangian mechanics
  • Investigate the properties of averaged Lagrangians in wave mechanics
  • Learn about the mathematical treatment of second-order derivatives in periodic functions
Physicists, applied mathematicians, and engineers working on wave mechanics and Lagrangian systems, particularly those interested in the dynamics of surface gravity waves.
nickthequick
Hi,
I'm concerned with finding the Euler-Lagrange equations for slowly modulated surface gravity waves and, as is custom in this type of physical problem, I would like to consider the averaged Lagrangian defined as
[tex]\mathcal{L}=\frac{1}{2\pi}\int_0^{2\pi}Ld\theta[/tex]
where [tex]\theta[/tex] is defined as [tex]\theta_x=k[/tex] and [tex]\theta_t=-\omega[/tex] where k and $\omega$ represent wave number and frequency respectively, which can also be functions of space and time. My Lagrangian, which comes from the physics of the problem, is [tex]L=L(\theta;x,t)[/tex] and the Euler-Lagrange equation then becomes
[tex]\frac{\partial L}{\partial \theta}-\frac{\partial }{\partial x }\frac{\partial L}{\partial \theta_x}-\frac{\partial }{\partial t}\frac{\partial L}{\partial \theta_t}=0[/tex]
If I integrate the above equation over [tex]\theta[/tex] from 0 to [tex]2\pi[/tex] and normalize, I know the first term goes to 0 because L is periodic (which again comes from the physics). So I'm trying to see if I can write the rest of equation in terms of the averaged Lagrangian, [tex]\mathcal{L}[/tex]. So my question is this, how does the term
[tex]\frac{1}{2\pi}\int_0^{2\pi}\frac{\partial }{\partial x }\frac{\partial L}{\partial \theta_x} \ d\theta[/tex]
relate to
[tex]\frac{\partial }{\partial x }\frac{\partial }{\partial \theta_x} \mathcal{L}[/tex]
Thanks!
Nick
I don't see any simple relation between the two.Although L is periodic, its second order derivatives may not be so.
What if we make the additional assumption that L and all of its derivatives are periodic?
  • · Replies 16 ·
  • · Replies 17 ·
