Density of states for a free electron
The discussion revolves around finding the density of states for a free electron gas in one, two, and three dimensions. The original poster expresses confusion regarding the appropriate equations to use for one-dimensional and two-dimensional cases, particularly in relation to the three-dimensional density of states provided in their textbook.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the need to derive the density of states for one and two dimensions, comparing it to the three-dimensional case. Questions arise about the differences between fermions and bosons and their implications for filling states.
Some participants have provided guidance on the derivation process and the conceptual differences between fermions and bosons. The discussion is ongoing, with multiple interpretations being explored regarding the application of the density of states equations.
The original poster notes confusion about the equations and concepts, particularly regarding the use of volume in the three-dimensional formula and the distinction between Fermi and Bose statistics. There is an emphasis on understanding the derivation rather than applying a single equation.
kottur
1. Find the density of orbitals (often called 'density of states') for a free electron gas in
one dimension, in a box of length L.
2. Find the density of orbitals for a free electron gas in two dimensions, in a box with
area A. Compare with the three dimensional case, eqn. (19) on page 187.
eqn. (19): [itex]D(\epsilon)=\frac{V}{2\pi^{2}}\left(\frac{2m}{h^{2}}\right)^{\frac{3}{2}}\epsilon^{\frac{1}{2}}[/itex]
The one above for the second problem because I can't use it for a one dimensional box because it's got V (Volume in it).
I'm not sure what equation I should be using, also I'm confused of Fermi and Bose. My professor told me there are two ways to find density of states, one with Fermi and one with Bose (if I understood correctly).
Any help is much appreciated! I really want to understand this! :)
There is no single equation you should be using. Your text probably derived the density of states in three dimensions for you. The problem is asking you to do the analogous derivations for the one-dimensional and two-dimensional cases. The idea is to make you think through what they did and apply those same techniques so that you'll understand where the final formula came from. So the place to start is to look up the derivation in your book.
The difference between fermions and bosons are how they fill up the available states, which will in turn affect the density of states. How do fermions and bosons behave differently?
Fermions have "half" spins and bosons have "whole" spins. I think I need to use fermions because my textbook uses it to derive the formula for 3D DOS.
You're right about the spins, but what does that have to do with how they fill up states?
  • · Replies 0 ·
