Problem involving hookes law and friction
This discussion focuses on solving a physics problem involving Hooke's Law and friction, specifically analyzing energy transfers. Key equations include spring potential energy (Es = kx²/2), kinetic energy (Ek = mv²/2), and gravitational potential energy (Eg = mgh). The method involves equating spring energy to kinetic energy to find velocity at different points, utilizing energy conservation principles. The role of friction is addressed by applying the work-energy principle, where the work done by friction dissipates kinetic energy until the object stops.
  • Understanding of Hooke's Law and spring mechanics
  • Familiarity with energy conservation principles in physics
  • Knowledge of kinematic equations and their applications
  • Basic grasp of friction and its impact on motion
  • Study the derivation and applications of Hooke's Law in various contexts
  • Learn about energy conservation in mechanical systems
  • Explore the effects of friction on motion and energy dissipation
  • Investigate advanced kinematic equations and their use in solving motion problems
Students studying physics, educators teaching mechanics, and anyone interested in understanding energy transfer in systems involving springs and friction.
guitarist2400
This is a question my professor asked in class and I did not understand his explanation at all, I found your forums hoping someone would break it all down for me
[PLAIN]http://i28.lulzimg.com/0cb917f809.jpg
I'm assuming you already know the answer, and you just need the methods explained more?This problems seems to be an energy problem.
The equations regarding energy are
Es = kx2/2
Ek = mv2/2
Eg = mgh
Also, the concept that E = fd is helpful.To find velocity at the top, the only energy transfer occurring is from spring energy to kinetic energy.
If you set the equations for those two equal you can solve for v.
Velocity at the bottom is almost the same process.
The transfer of energy is from the velocity at the top and from gravity to velocity at the bottom (you can also set spring energy and gravity energy equal to the kinetic energy at the bottom).
Setting Eki (or Es) + Eg = Ekf will allow you to solve for vf.
Distance the object travels with friction can be used with kinematic equations, if you solve for acceleration.
I find its easier to use energy, since you already will have solved for energy at the bottom (Ekf).
Since the friction will dissipate all of that kinetic energy before the object stops, you can use the E = fd with E being Ekf and F being uFn.
  • · Replies 35 ·
