What is the mass of the meter stick?
  • Thread starter Thread starter Quipzley
    Mass Meter
The problem involves a meter stick balancing on a knife-edge with additional weights (coins) placed at a specific point. The objective is to determine the mass of the meter stick based on the conditions of balance and torque.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the concept of torque and its application to the problem, with some attempting to set up equations based on moments and forces. There are questions about how to calculate the torque of the meter stick itself and how to define variables for the masses involved.
Some participants have provided guidance on defining variables and setting up equations to sum moments to zero. There is an ongoing exploration of the relationship between the torques produced by the coins and the meter stick, with no explicit consensus reached on the final mass calculation.
Participants are working under the assumption that the system is in equilibrium and are considering the effects of the weights and the center of mass of the meter stick in their calculations.
Quipzley
A meter stick blances horizontally on a knife-edge at the 50.0 cm mark. With two 5.00 g coins stacked over the 12.0 cm mark, the stick is found to balance at the 45.5 cm mark. What is the mass of the meter stick?
I know it is going to be having equal torques. The torque on one side should be .01 kg*9.8 m/s^2* .335 m = .03283 N*m + the torque of the .335 m of meter stick. The other side is just the torque of the .455 m of stick. I'm not sure how to calculate the torque of the meter stick.
The answer is supposed to be 74.4 g.
Pick a point, any point, and sum moments to zero. Define your variables; mass of stick and coins, ms and mc; forces, a, b, and g. Solve for ms.
The stick's centre of mass experiences a weight force mg, (50.0 - 45.5) cm from the knife-edge, producing a torque of mg(0.045 m). This torque is balanced by the torque of the coins (0.01000 kg)g(0.335 m) = mg(0.045 m). Therefore m = 74.4 g.
9K
  • · Replies 33 ·
23K
42K
