Resistance of a sphere of resistivity rho and radius S
The discussion focuses on calculating the resistance between two points on a sphere with resistivity ρ and radius S. The user employs the formula dR = ρ * dl/A, where dl = -S Sin(θ) d(θ) and A(θ) = π {S Sin(θ)}². The challenge arises when evaluating the definite integral from θ = 0 to π, as the strip element reduces to a point at the endpoints, leading to difficulties in obtaining a finite resistance value. The user seeks assistance in resolving this integral issue.
  • Understanding of electrical resistance and resistivity concepts
  • Familiarity with calculus, particularly integration techniques
  • Knowledge of spherical coordinates and their applications
  • Experience with mathematical modeling of physical phenomena
  • Study the evaluation of definite integrals in spherical coordinates
  • Research the application of resistivity in three-dimensional geometries
  • Explore advanced calculus techniques for handling limits and singularities
  • Investigate numerical methods for approximating integrals in complex geometries
Physics students, electrical engineers, and mathematicians interested in advanced resistance calculations and integral evaluation in spherical geometries.
Sadiq
I calculated the resistance between two points (P and Q) on a sphere that are located on the two ends of a diameter by dividing the sphere into thin strips of thickness dz that are in series perpendicular to the line PQ (say the z-axis). I can get an expression for the indefinite integral in theta (the polar angle theta, z = S Cos (theta), and S= radius), however I run into problem when evaluating this definite integral for theta = 0 to pi. Apparently the fact that the strip element becomes a points at the ends is causing this problem. I use dR=rho * dl/A with dl = -S Sin(theta) d(theta) and A(theta) = pi {S Sin(theta)}^2. What is going wrong here? Because I know that there must be a finite resistance between two such points.
I need help!
I'm a spanish coach from Barcelona and I have a problem.
I need some information about "curve fenomenon" in velodrom cycling. When a cyclist go into a curve power is less than in straight and velocity is high to a straight. Please do you explain this fenomenon?.
My e-mail is ardcarlos@hotmail.com
Thank you very much!
