Velocity of fluid at rear of airfoil
  • Context: Undergrad
  • Thread starter Thread starter alpha_wolf
    Airfoil Fluid Velocity
The discussion revolves around the velocity of fluid at the rear of an airfoil in laminar flow, particularly in the context of potential flow theory and the implications of the D'Alembert Paradox. Participants explore the conditions under which the fluid velocity is zero at both the front and rear of the airfoil, as well as the physical and mathematical explanations for these observations.
  • Some participants assert that in laminar flow around an airfoil, the velocity is zero at both the front (stagnation point) and rear due to the nature of potential flow.
  • Others reference the D'Alembert Paradox, suggesting that symmetric aerodynamic bodies experience no drag in potential flow, leading to zero velocity at the rear.
  • A participant questions the physical reasoning behind the velocity dropping to zero at the rear, despite fluid particles approaching from different angles.
  • Some argue that if the trailing edge of the airfoil is not perfectly sharp, there is space for air molecules to remain undisturbed, potentially affecting the velocity at the rear.
  • Another participant suggests that if the airfoil were perfectly sharp, the streamlines would collide tangentially rather than crossing, which could influence the velocity at the rear.
  • Concerns are raised about the relationship between pressure gradients and the recovery of velocity at the rear, with some suggesting that irreversibilities could prevent the velocity from reaching zero.
  • There is a discussion about the practical implications of achieving parallel streamlines at the trailing edge, noting that this would require an infinitely long wing.
Participants express a mix of agreement and disagreement regarding the explanations for zero velocity at the rear of the airfoil. While some support the mathematical reasoning, others seek further physical justification and raise questions about the implications of non-ideal conditions.
Limitations include assumptions about idealized conditions in potential flow, the dependence on the sharpness of the airfoil's trailing edge, and the effects of turbulence and irreversibilities on flow behavior.
alpha_wolf
Hello, we've just watched a few movies about drag, reynold's number, etc., as part of our fluid dynamics course. In one of the movies, they claimed that given a laminar flow around an arifoil, the velocity of the fluid at both ends of the airfoil is zero. Now, I understand why the velocity is zero at the front of the foil (at the stagnation point), but why is it also zero at the rear end?
I'm not sure of what I'm saying. In laminar flow (I mean potential flow) there is a paradox called D'Alembert Paradox. That states all symmetric aerodynamic body has no drag inmersed in a fluid stream. Why? The flow is deccelerated until the body nose, where v=0 and the static pressure P=Pmax. As the flow goes over the body shoulders it losses static pressure at the same time gaining velocity. When the flow reaches the rear part, the velocity becomes zero, and the pressure is P=Pmax because in potential flow there are not any losses of pressure (isentropic flow). So that, the integral of the pressure over the body (drag coefficient) is zero.
Why is v=0 at the rear?. Think of it. There are two stream lines (one traveling at the higher part and another traveling at the lower part of the body). When both streamlines crash into each other at the rear part, the velocity must be zero at that point. That's because of the definition of streamline. A streamline is a line tangential to the velocity vector. If two streamlines are defined just at one space point, the velocity has to be zero at that point.
Of course, it only happens at potential flow. Turbulent regimes are quite different. Surely it is formed a vortex at the rear due to the Kelvin's Theorem.
What do you think of this?
Yes, this is what was shown in that movie (among other things). Although they didn't use any integrals, and didn't mention the term "potential flow".
Ok, that makes sense, I guess. But that's a purely mathematical explanation. What is the physical reason for the velocity to drop back to zero? I mean you've got these fluid particles coming in from the top and from the bottom, but they're coming in at an angle. I can see why their vertical velocities may cancel out, but why do the horizontal also zero out? Or, looking from a slightly different angle, why does the pressure rise back to Pmax? For that matter, why does it rise at all?? (Don't tell me it rises because the volcity drops - it's the other way around if I'm not mistaken).
Yes, turbulent flow is quite a different story. There you get backflow, boundary layer separation, and all sorts of other mess...
Think of it this way - unless, the trailing edge of an airfoil is perfectly sharp, there will be room behind it for air molecules to sit undistrubed by the straight flow of air above and below.
Are you implying that if the rear end was sharp to within atomical precision, the velocity at the rear end would not be zero? How does that sit with the mathematical definition of a streamline (see Clausius2's post)?
It is consistent with russ_watter said. If the airfoil is perfectly sharp, both ends of the rear are infinitesimally tangential, so that when both streamlines come one into other they do not cross, but they collide tangentially.
In my opinion, mathematics and reality are the same thing at Fluid Mechanics. I have given to you a mathematical explanation, well, if you take it carefully you will see it has a physical explanation. The velocity drops to zero because fluid particles are braked because of the positive pressure gradient. If the gradient is not enough to reach the leading stagnation pressure (there are pressure drops due to irreversibilities) then you won't recover the rear stagnation point, and v is not 0 at the rear.
Actually, I left out that second part: infinitessimally tangential. You got what I meant though. In practice, actually getting the streamlines parallel at the trailing edge would require an infinitely long (chord) wing, with a symmetric/hyperbolic cross-section toward the trailing edge.
  • · Replies 30 ·
  • · Replies 17 ·
