Drawing a Jack in the Box w/ AutoCAD & MSCAD Questions
  • Thread starter Thread starter tribdog
    Autocad
The discussion revolves around using AutoCAD and MSCAD to create a drawing of a Jack in the Box based on provided dimensions and points. Participants explore various commands and techniques for accurately drawing lines and shapes in the software.
  • Homework-related
  • One participant inquires about how to specify line lengths directly in AutoCAD, noting the challenges faced with drawing and erasing based on measured dimensions.
  • Another participant suggests using the "@" command to draw lines of a specific length at a designated angle, explaining the syntax involved.
  • A different participant proposes using absolute and relative coordinates with the line command to connect points, indicating that the drawing task may be more complex than initially assumed.
  • Further clarification is provided about the use of the '@' key for relative coordinates in AutoCAD.
  • A side discussion arises regarding the differences between the student and professional versions of AutoCAD, focusing on performance and printing limitations.
Participants generally agree on the utility of the '@' command for drawing lines, but there is no consensus on the complexity of the drawing task or the differences between software versions.
Some assumptions about the drawing task's complexity and the specific capabilities of MSCAD versus AutoCAD remain unresolved. The discussion does not clarify the exact nature of the points provided for the Jack in the Box drawing.
Individuals interested in CAD software, particularly those working on technical drawings or learning to use AutoCAD and MSCAD for design projects.
tribdog
I have a bunch of points and I need to turn them into a drawing of a Jack in the Box. The guy who shot it in couldn't get quite a few points, but he did measure them with a tape and gave me the dimensions. I've been using the offset command to put in lengths he supplied, but that involves a lot of drawing and erasing. My question is is there a way to tell AutoCad how long of a line you want? Also I'm using MSCad not AutoCad but I think the commands are all the same.
Well, you could use the "@" comand.
For example, let's say you want to draw a line that is 10 units long at an angle of, say, 45 degrees. What you would do is specify the beginning point of the line, just like you would normaly, then you type on the comand box [tex]@10<45[/tex] (no spaces in between)
The @ symbol tells AutoCAD that the next instructions should be followed. the 10 is the length, the < signs tells AutoCAD in what angle the line should be drawn. This is handy when you need to draw specific lines at various angles with respect to something else than the grid.
If what you're doing is essentially drawing lines between co-ordinates, you could use the line command with absolute co-ordinates. If you know the co-ordinates of some of the points relative to others, you can use the line command with relative co-ordinates (line from x,y,z to @x1,y1,z1 draws a line from (x,y,z) to a new point that has distances of x1, y1 and z1 from the first point, along the 3 directions).
I suspect you problem is actually more tricky than this. WaR's suggestion is good for drawing lines of a certain length.
As the others have said, the '@' key tells autocad that to use coordinates relative to the last entry.
This is somewhat off topic. :rolleyes:
Is there a big difference, other than price, between the student and the regular(or professional I guess) version of autocad?
I am unaware of a big difference performance wise. The real difference comes when you plot (print) your work. You have "AutoCAD student version" printed out at every side of the paper.
Ok cool, thanks. Having "AutoCAD student version" shouldn't bother me too much :smile:
  • · Replies 20 ·
