Expected value of a semicircle
The discussion centers on calculating the expected value E[X] for a point chosen uniformly within a semicircle defined by the equation {(x,y)|x²+y²≤r², y≥0}. Participants explore methods to simplify the calculation, with one contributor suggesting that due to the semicircle's symmetry, the expected value of X is 0. This conclusion is confirmed through symmetry arguments, indicating that the expected value for a regular circle would yield the same result.
  • Understanding of uniform probability density functions (PDF)
  • Familiarity with expected value calculations in probability
  • Knowledge of symmetry in geometric shapes
  • Basic concepts of moment calculations in statistics
  • Study the properties of uniform distributions in geometric shapes
  • Learn about symmetry arguments in probability theory
  • Explore expected value calculations for different geometric figures, including circles and semicircles
  • Investigate the relationship between moments and expected values in statistical analysis
Students in probability and statistics, mathematicians interested in geometric probability, and educators teaching concepts related to expected values and symmetry in distributions.
de1337ed
Point is chosen at random (uniform PDF) within semi-circle: {(x,y)|x2+y2≤r2, y≥0}
Basically, I'm supposed to find E[X] for this problem
2. The attempt at a solution
I know how to do it, in a very long-winded fashion
(find fY(y), and E[X|Y=y] etc).
But my teacher says that there is an easier way that doesn't involve a lot of calculations, anyone see it?
Thanks
EDIT;;;;
I think i might have gotten it, because the semicircle is an even function, the expected value of the first moment is 0. Can someone confirm this also?
Also, does this apply to a regular circle as well?
That is not a precise statement. What function are you referring to? If you are referring to the equation for the boundary of the semi-circle, that doesn't justify any conclusions about the moment of X.
You could argue by symmetry if the distribution function that the mean value of X in the semicircle is 0. ( Don't say "expected value of the first moment" because the first moment of X is the expected value of X.)
13K
