| New Reply |
Riemannian surfaces as one dimensional complex manifolds |
Share Thread |
| Nov16-11, 01:59 PM | #69 |
Riemannian surfaces as one dimensional complex manifoldsI know the globally flat part doesn't sound right, I'm not sure about it either but all the time I've had the feeling that I'm not being able to get across what I mean, I don't mind being wrong but it bothers me not to be able to express what i mean in a sound mathematical way, so I guess I have to study this harder. |
| Nov16-11, 05:29 PM | #70 |
Recognitions:
The Mobius band is a non-orientable surface in 3 space. It naturally has a flat metric. There are no closed surfaces without boundary in 3 space that are unorientable. For instance the Klein bottle can not be embedded in 3 space.
| Nov16-11, 06:53 PM | #71 |
Recognitions:
I will try to help if you're willing to work with me.
There are many extrinsic curvatures a surface can have, depending on the dimension of the ambient manifold. For example, I can pinch the north and south poles of a sphere, pull on them, and twist them by any arbitrary amount. All of these are measured by various extrinsic curvatures. There is one special extrinsic curvature, the Gauss curvature, which Gauss proved is actually intrinsic; that is, independent of the ambient manifold into which the surface is embedded. From the extrinsic point of view, the Gauss curvature is the product of the principal curvatures (which are curvatures of curves on the surface, measured with respect to the ambient space). From the intrinsic point of view, the Gauss curvature is one-half the Ricci scalar intrinsic to the surface. But the two are always equal to each other. This is why it is quite strange to me (and likely everyone else) that you keep harping on embeddings in H^3 being somehow different from embeddings in R^3. They are not. In two dimensions, it turns out that a nowhere-vanishing 2-form can also be interpreted as a complex structure. Hence all orientable 2-surfaces are complex manifolds (in fact, they are Kaehler). The total curvature of any topological sphere must be positive. Using the Poincare ball model, H^3 is the open ball on the interior. It does not include the boundary. In fact, H^3 is homeomorphic to R^3; it has no boundary! (More on that later). Looking at a horosphere in the Poincare ball model, the horosphere is represented by what looks like a round sphere touching the boundary. However, one point of this round sphere lies on the boundary of the ball model, and therefore does not properly lie within H^3. Therefore, a horosphere is not actually an embedding of the sphere into H^3, because there is one point of the sphere which is not inside H^3. More properly speaking, the horosphere is the embedding in H^3 of a "sphere with one point removed". Or in other words, it is a 1-point de-compactification of the sphere; i.e., a horosphere is actually an embedding of the infinite plane! As I have pointed out before, this is why it is possible for the horosphere to be globally flat. OK, so then what is the boundary of the Poincare ball model? This is easiest to explain after we see what the Poincare ball model is. Start with a more natural model of hyperbolic space: the hyperboloid model. The hyperboloid model is easiest to visualize from by embedding it isometrically in Minkowski space. Starting with the metric [tex]ds_4^2 = dx^2 + dy^2 + dz^2 - dw^2[/tex] consider one sheet of the hyperboloid [tex]w^2 - x^2 - y^2 - z^2 = 1[/tex] This is a 3-hyperboloid that lies entirely within the future light cone (and asymptotically approaches it at infinity). If we compute the induced metric on this hyperboloid, we get [tex]ds_3^2 = d\rho^2 + \sinh^2 \rho \, d\theta^2 + \sinh^2 \rho \, \sin^2 \theta \, d\phi^2[/tex] The reason I call this a more natural model of H^3 is because now it is clear that H^3 is homogenous, isotropic, and infinite in extent in all directions. Also, it embeds isometrically within the future lightcone, so you can imagine what it looks like without distorting distances (whereas, the Poincare ball model must distort distances in order to fit all of H^3 within a ball). To map between this model and the Poincare ball model, one actually uses stereographic projection! Unfortunately I can't draw a picture here. But imagine lines emanating from the origin of Minkowski space and intersecting the H^3 hyperboloid. Then map each point of H^3 to the unique point where each of these lines intersects the hyperplane [itex]w = 1[/itex]. It is easy to show that the result is the Poincare ball model, with the usual metric. We can also easily see that the "boundary sphere" of the Poincare ball model is the image of the lightcone itself under this stereographic projection. Since stereographic projection is a conformal transformation, we can call this boundary a "conformal boundary". Under stereographic projection, H^3 itself maps to an open ball in E^3, whereas the lightcone maps to the boundary of this ball. To obtain a closed ball, we must add a whole 2-sphere's worth of points to H^3. It is important to realize that H^3 itself is not a closed ball. To make it into one, we must conformally compactify H^3 and add a sphere's worth of points. The result turns H^3 into a closed ball in Euclidean space. Therefore if we want to consider spheres in the Poincare ball model that actually touch the boundary, then we can't use the hyperbolic metric to discuss them! After the conformal compactification required to give us the boundary, we will have a Euclidean metric inside the ball, and the spheres touching the boundary are simply ordinary, round spheres. Alternatively, we can de-compactify, which turns the open interior of the ball into an honest H^3, and turns the horospheres into honest R^2's. |
| Nov16-11, 07:56 PM | #72 |
Recognitions:
this is becoming more and more fun! thanks for the question, tricky. this is the way real math conversations go, when everyone is feeling her/his way, (with all respect).
| Nov16-11, 09:12 PM | #73 |
Recognitions:
| Nov16-11, 09:21 PM | #74 |
Recognitions:
Sometimes an embedding does determine a Riemannain metric that is different than the one that the manifold inherits by restricting the ambient inner product to its tangent planes. Take the case of a surface embedded in Euclidean 3-space that has positive Gauss curvature. Then the eigen values of the second fundamental form are strictly positive so they determine a new Riemannian metric. I do not know if the manifold with this new Riemannian metric can be embedded in 3 space. I guess if the change is small it will still have positive curvature.
| Nov16-11, 11:54 PM | #75 |
| Nov17-11, 01:08 AM | #76 |
Recognitions:
| Nov17-11, 04:09 AM | #77 |
| Nov17-11, 05:28 AM | #78 |
Just one point, as I said in a hyperbolic 3-manifold I would say we'd have a compact conformal boundary that will not require the space in the ball to be euclidean, as it is evident the ambient space in a hyperbolic manifold has a hyperbolic metric. Maybe it is worth recalling here that there are some differences about some notions in topology and in manifold theory, for instance the concept of boundary in topology differs slightly from that in manifolds, or the concepts of closed and open in certain contexts. |
| Nov17-11, 12:01 PM | #79 |
Recognitions:
H^3 as a manifold does not include the conformal boundary. It can't include the conformal boundary, because you can't just add points that are infinitely far away (any interval of infinite length must be open). You can add these points to the conformal compactification of H^3; but the conformal compactification of H^3 is honestly an open ball in E^3. This is analogous to the fact that the conformal compactification of R^2 is honestly an open region of a round sphere. The conformal transformation that compactifies the space actually changes the curvature. It makes H^3 flat, and it makes R^2 curved. In fact, the coordinates in the Poincare ball model can be thought of as exactly the map from H^3 to E^3 that accomplishes this conformal compactification. It's easy to see that conformal compactifications change curvature: just stick a conformal factor in front of the metric and recompute the curvature, you'll find it changes in a simple way: http://en.wikipedia.org/wiki/Ricci_c...rmal_rescaling |
| Nov17-11, 01:04 PM | #80 |
"A hyperbolic 3-manifold is a 3-manifold equipped with a complete Riemannian metric of constant sectional curvature -1. In other words, it is the quotient of three-dimensional hyperbolic space by a subgroup of hyperbolic isometries acting freely and properly discontinuously." This subgroup happens to be isomorphic to the the automorphism group of the Riemann sphere. |
| Nov17-11, 02:26 PM | #81 |
Recognitions:
My previous response assumed you were talking about H^3. In your above post, you have changed all the definitions, quite literally changing the rules of the game.
You must be clear what you're talking about in the first place. |
| Nov17-11, 02:43 PM | #82 |
Recognitions:
I do know a bit about conformal geometry of surfaces, since this is important to string theory. I can try to respond to your new questions later.
For now, it might help for you to go back and read some of Mathwonk's and Homeomorphic's earlier comments concerning local vs. global conformal transformations. I think the discussion on Wikipedia is incomplete again. Wikipedia seems to focus on conformal classes of local metrics, but these kinds of conformal transformations do not preserve global topology. For now, I can respond to this: If you do quotient H^3 by a discrete group, you get a closed manifold without boundary (and with constant negative curvature). This is analogous to the quotient of R^2 by a discrete group (giving you, e.g., the torus), or the quotient of H^2 by a discrete group (giving you the double torus and higher-genus Riemann surfaces). You can imagine a quotient of H^3 by a discrete group as a tesselation of H^3 by regular polyhedra, where the quotient manifold is one such polyhedron with various faces identified. |
| Nov17-11, 04:24 PM | #83 |
Recognitions:
For a surface embedded in a 3 dimensional Riemannian manifold calculation shows that the Riemann curvature tensors of the 3 dimensional manifold and the surface are related by a formula.
R[itex]_{ambient}[/itex](x,y,x,y) = R[itex]_{surface}[/itex](x,y,x,y) + A(x,y)[itex]^{2}[/itex]-A(x,x)A(y,y) where A(x,y) is the normal component of the covariant derivative of y with respect to x. The Gauss curvature of the surface thus satisfies the equation, G = R[itex]_{ambient}[/itex](x,y,x,y)/|x^y|[itex]^{2}[/itex] - (A(x,y)[itex]^{2}[/itex]-A(x,x)A(y,y))/|x^y|[itex]^{2}[/itex] If the sectional curvature of the ambient manifold is constant,K, as in Eudlidean space or some other flat 3 manifold or in hyperbolic 3 space then this equation becomes G = K - (A(x,y)[itex]^{2}[/itex]-A(x,x)A(y,y))/|x^y|[itex]^{2}[/itex] If k = 0 this is the usual equation for the Gauss curvature with respect to the determinant of the second fundamental form. For the horosphere, G = 0 so the normalized determinant of the second fundamental form is equal to 1. It is important to realize though that this equation in no way says that if the surface is a sphere that G can be identically 0. G is still the intrinsic curvature no matter how it is embedded in another manifold. |
| Nov17-11, 04:57 PM | #84 |
| Nov17-11, 07:54 PM | #85 |
Recognitions:
I wonder if this means that an observer in the three sphere looking at a flat torus would see it as negatively curved - assuming light followed geodesics in the 3 sphere. |
| New Reply |
Similar discussions for: Riemannian surfaces as one dimensional complex manifolds
| Riemannian Manifolds, John M. Lee | Science Textbook Discussion | 1 | ||
| Laplacian on Riemannian manifolds | Differential Geometry | 2 | ||
| Cometrics on Sub-Riemannian manifolds | Differential Geometry | 0 | ||
| Riemannian Manifolds and Completeness | Calculus & Beyond Homework | 1 | ||
| Riemannian manifolds | Differential Geometry | 16 | ||
