Register to reply
Pick number between 0 and 9
by Cylab
Tags: number, pick
Share this thread:
Cylab
#1
Nov2-11, 04:45 AM
P: 54
you pick three numbers between 0 and 9 (no multiplication of number). You win if you pick the three numbers in the exact order that they are drawn. Say you pick 3-2-1. What is the probability of winning, given the winning numbers are three in descending order (1st>2nd>3rd).
Phys.Org News Partner Science news on Phys.org
What lit up the universe?
Sheepdogs use just two simple rules to round up large herds of sheep
Animals first flex their muscles
HallsofIvy
#2
Nov2-11, 07:47 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,533
Since the numbers do not repeat and are decreasing, the first number must be 3 or more. There are 7 such numbers, 3, 4, 5, 6, 7, 8 , 9, so the probability of picking the first number, x, correctly is 1/7. The probability of picking the second number, y, correctly is 1/(x- 1) and the probability of picking the third number correctly is 1/(y- 1).
Note that for each x the second probability differs and for each y the third does. Take the sums of the probabilities over all possible values of x and y.
Cylab
#3
Nov15-11, 03:16 AM
P: 54
Thanks a lot,, Yes, it makes sense, but it is going to be big big big calculation...
wondering if there is any alternative?
2milehi
#4
Nov15-11, 11:20 PM
P: 109
Something doesn't seem right. The first number needs to be from the range of 2 through 9 and that is an 8 in 10 chance. Then there is a 1 in 9 chance for the second number and a 1 in 8 chance in the third number.
Ray Vickson
#5
Nov16-11, 01:09 AM
Sci Advisor
HW Helper
Thanks
P: 5,060
Quote Quote by 2milehi View Post
That is wrong. The chances associated with the second number depend on what was the first number. For example, if the first number is 3 there is just one allowed choice of second number, but it the first number is 9 there are 7 choices for the second number (8,7,6,5,4,3, or 2), etc.
RGV
willem2
#6
Nov16-11, 01:25 PM
P: 1,396
Quote Quote by Cylab View Post
Your problem is a bit unclear. Is the procedure as follows?
You choose 3 numbers a,b,c from the set {1,2,3,4,5,6,7,8,9} such that a>b>c.
someone else puts 9 balls numbered {1,2,3,4,5,6,7,8,9} in a bag, and draws out 3 at random without replacement. You're being told that is just so happened that those 3 balls were in the same order as your pick.
(or the drawing was repeated with refilling the bag after each set of 3 draws until the balls were drawn out in descending order)
If that is the case, then the probability is just 1 divided by the number of triples (a,b,c) with a>b>c. (should be easy)
The reply of HallsifIvy is then wrong, since the probability of getting a 3 or a 9 on the first draw isn't the same. There's only one combination that starts with a 3, and many that start with 9, so with the given information, 9 is far more likely than 3.
I believe it would be correct if all balls that are bigger than a ball that's already drawn, or that couldn't produce a valid combination (1,2 on the first draw and 1 on the second)
would be thrown back in the bag.
2milehi
#7
Nov16-11, 08:55 PM
P: 109
I might be misunderstanding the original question. Do the numbers have to descend by one like in your example, or just have be lower than the previously chosen number?
Register to reply
Related Discussions
Where does Calculus II pick up? Academic Guidance 12
Game Strategy (pick the lowest unrepeated number) General Math 4
Another pick a number game General Discussion 11
No, you don't need to pick up after yourself! General Discussion 10
Bone to pick Forum Feedback & Announcements 13
