Theory behind thermal insulation
This discussion focuses on designing highly insulating structural load-bearing walls using local materials, emphasizing the importance of understanding insulation dynamics. Key factors influencing R-value include minimizing solid conduction through materials like supercooled glass, preventing gas movement to reduce convection, halting heat transfer via radiation, and managing the interaction between solids and gases. The conversation highlights the inherent contradiction between load-bearing and insulating properties, suggesting a multi-layered approach to wall construction. Proper arrangement of materials to allow water vapor diffusion is crucial to prevent moisture-related issues.
  • Understanding of R-value and thermal insulation principles
  • Knowledge of material properties, specifically supercooled glass and its molecular structure
  • Familiarity with heat transfer mechanisms: conduction, convection, and radiation
  • Basic principles of building construction and moisture management
  • Research advanced insulation materials and their R-values
  • Explore the properties of supercooled glass and its applications in construction
  • Study the laws of thermodynamics as they relate to gas interactions in insulation
  • Investigate multi-layer wall construction techniques for optimal thermal performance
Architects, construction engineers, and builders interested in optimizing thermal insulation in structural designs, particularly those focused on sustainable materials and moisture management.
AnnVole
I wish to design highly insulating structural load-bearing walls using local materials. Part of that effort requires an understanding of the dynamics of current insulation materials and why some are much higher in R-value while using the same base material. Part of my study so far suggests that there are 4 aspects to consider:
  • The solids conduct as little as possible and that includes using a glass material (supercooled liquid) that has less molecular connections then a crystalline solid and thin strands of material that conduct less based on the cross-section of the strand
  • Stopping the movement of gases as gases have low conductivity but can move heat via convection movement
  • Stopping heat movement via radiation
  • The interaction between solids and gases and especially combinations of different gases that creates reduced molecular interactions
The interactions of gases in the presence of solids is the part that brings in dozens of laws about gases and molecular science that are what I hope to learn more about. My question is if there are any explanations of thermal insulation that touch on this kind of science that I can read online.
I can not help you with theory, but you may not need it.
First you may be interested to know that 'load bearing' and 'insulating' are somewhat
contradictory requests for one material to satisfy. Strong materials are typically
dense and bad insulators, while most insulating materials are not mechanically strong.
This ist typically resolved by building the wall from several layers, the strong, heavy innermost
layer will bear the loads and will also have a great heat capacity keeping the temperatures
comfortable even under external heat or cold influence.
The insulating layer will be on the outside, it is made of insulating material and will restrict
heat loss. The outermost layer will be a mechanical protection, also against weather and will
provide for nice optics.
Be sure to arrange materials by decreasing resistance against water vapor diffusion, so
that humidity can leave your construction freely. Failure to do so will result in wet insulation
or mold.
Play with floor, wall or ceiling constructions on the site
http://www.u-wert.net/berechnung/u-wert-rechner/?cid=o5rzklJB&lang=en"
you will quickly get the feel for it!
hth.
gnasch
  • · Replies 0 ·
