Can Blood Literally Boil Inside the Human Body?
  • Thread starter Thread starter SonicaBoxx
    Blood Boil
The discussion revolves around the hypothetical scenario of blood boiling inside the human body, exploring the conditions under which this might occur, the physiological effects, and related experiences. Participants examine both theoretical and practical aspects, including temperature, pressure, and biological reactions.
  • Some participants question whether blood can literally boil and under what circumstances this might happen.
  • One participant suggests that reaching a core body temperature of 100 degrees Celsius would lead to boiling, causing swelling and leakage of blood.
  • Another participant humorously proposes the idea of microwaving oneself, implying that survival would be unlikely before blood boiling became a concern.
  • It is noted that low pressure could allow blood to boil at temperatures below 100 degrees Celsius, referencing the experiences of astronauts and pilots.
  • Concerns are raised about the effects of high temperatures on blood's ability to carry oxygen and the denaturation of proteins, which would occur before reaching boiling point.
  • Participants discuss the implications of exposure to vacuum, questioning whether fluids in the body would explode or evaporate under such conditions.
  • Some participants share anecdotal experiences related to extreme temperatures, such as sauna use and its effects on the body.
  • There is a mention of the bends, a condition related to dissolved gases in the blood, which could occur before boiling.
Participants express a range of views on the boiling of blood, with no consensus reached. Some agree on the role of pressure and temperature, while others challenge the likelihood of explosion or boiling under specific conditions.
Limitations include assumptions about temperature and pressure conditions, the biological responses of blood to heat, and the effects of solutes in blood on boiling points. The discussion does not resolve these complexities.
SonicaBoxx
Let's say that somehow your blood could literally boil. First of all, is that even possible? Second, how? What circumstances would you have to be in for your blood to boil?
Also, in a kind of related question, if your blood did boil, would it cause you to swell and/or explode?
Biology news on Phys.org
If your core body temperature approached 100 degrees you would boil. This would make you swell and probably leak a lot of bubbling blood through your now well burnt flesh.
Or you could microwave yourself and cook from the inside out. I doubt you'd live long enough to worry about the fact that your blood was boiling.
In an effort to clarify both question and answer:
SonicaBoxx: can blood start boiling purely from internal biological/chemical interactions?
Ryan_m_b: No
Did I paraphrase this discussion correctly?
Ryan_m_b: No
Yup :approve:
You don't need to get to 100°C to reach the boiling point. Think low pressure.
Astronauts and pilots of high flying jets don't use pressure suits without a reason.
The link by Ygggdrasil was very interesting. Sweating/panting saves you, as it uses evaporation to cool a thin layer of air around you. But surely if the temp of room was raised high enough, this separated area of air would evetually heat to above boiling point as well and then you would boil.
How much cooler is the thin bit of air around you that evaporation of sweat cools for you?
If you stay there long enough, all liquid that is used for sweating, will be used up and then would you die? How long would this take?
Also if ( and when) your blood boils, would other bodily fluids such as spit,snot, sperm/vaginal fluids boil with it?
I have read about pilots who having ejected at very high altitude could feel their saliva boil. With enough time I'm sure their blood would boil.
I once had the opportunity to use the sauna at the Hotel Kempinsky Berlin and I noticed the thermometer read 100 deg. Another guest explained the proper procedure was to stay in the sauna 10 min. (there was a 10 min. hour glass on the wall) and then soak in a 0 deg. temperature controlled bath. The two temperatures should be alternated 5 times.
My blood did not boil but I can report that a bath in water at 0 deg., even after a 10 min. sauna at 100 deg., still feels like a bath in water at 0 deg.
Temperature in sauna goes up to 120 deg C in upper parts if memory serves me well. However, air in sauna has humidity low enough to allow perspiration to keep body temperature in the correct range.
you only have to drink one beer in the sauna :biggrin:
Long before you reached the boiling point (which would be higher than 100 C, because of the solutes in blood), blood would have lost sufficient ability to carry oxygen to sustain life. With increasing temperature, less oxygen is able to bind to hemoglobin (good locally when your warmed up muscles are trying to coax that oxygen out of blood, but bad systemically if your blood can't get the oxygen from your lungs to bind). Also, keep in mind that blood contains a lot of proteins that are going to be denatured by heating. You'll be cooking those. Also, the other gases dissolved in the blood will bubble out before the water in it hits the boiling point (the bends anyone?).
What if you cut your finger and then jump out of a spaceship into vacuum?
Don't worry about that finger cut, you'd explode anyway, see..:
Explode?
I imagine that any moisture (or blood) on your skin would evaporate immediately.
But aren't the fluids in your body contained and as such under pressure?
Would the pressure difference be large enough to explode?
Somehow that seems unlikely to me...
(I'd keep my eyes closed though.)
Explosion is probably unlikely, but I would expect at least some kind of bends.
yes you are right, what I said was unfounded and exagarated. Anyway here is some more information
http://imagine.gsfc.nasa.gov/docs/ask_astro/answers/970603.html
If blood was water, at 37C body temp it would boil at some http://cr4.globalspec.com/thread/8538, which concurs with the water on his tongue boiling.
Maybe he was very close.
Nice article!
And yes, apparently one gets possibly "the bends".
  • · Replies 22 ·
  • · Replies 17 ·
