Solving a Set of Equations with Python Odeint | Code and Example
  • Context: Python
  • Thread starter Thread starter goldin2008
    Ode Python
The discussion revolves around solving a set of equations using Python's odeint function from the SciPy library. Participants are seeking assistance with code that produces incorrect output, focusing on the implementation of a complex mathematical function.
  • Homework-related
  • One participant expresses difficulty in obtaining the correct output from their odeint implementation and requests help.
  • Another participant presents a similar problem with the same code structure, indicating a potential common issue or misunderstanding in using odeint.
  • Both participants share extensive code snippets that define a function with multiple mathematical operations and parameters.
  • There are indications of complex mathematical expressions involving exponential functions, trigonometric functions, and various parameters that may affect the output.
There is no consensus on the specific issue causing the incorrect output, as both participants present similar problems without resolving their differences in understanding or implementation.
The code snippets provided are lengthy and complex, with numerous mathematical operations that may introduce errors. The discussions do not clarify the assumptions or dependencies that might affect the results.
goldin2008
I want to solve a set of equations using Python odeint, but output shows me it is wrong.
Can you help me? Thanks.
Code:
# -*- coding: utf-8 -*-
from scipy.integrate import odeint
import numpy as np
from pylab import *
import math
def func(y, t, k, c, Zr):
#px, py, pz, x, y, z = y & px=y[0]; py=y[1]; pz=y[2]; x=y[3]; y=y[4]; z=y[5]
# apply func formula
return (
-k/((1+y[5]**2/Zr**2)**(1.0/2))*exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*math.sin(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))
-((-1.0/2*(1+y[5]**2/Zr**2)**(-3.0/2)*2*y[5]/Zr**2*math.exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))+(1+y[5]**2/Zr**2)**(-1.0/2)*(math.exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*(1+y[5]**2/Zr**2)**(-2.0))*2*y[5]/Zr**2*(y[3]**2+y[4]**2)/(2*Zr/k)*math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))-math.exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*math.sin(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))*(k+(y[3]**2+y[4]**2)*(Zr**2-y[5]**2)/(2.0/k*(Zr**2+y[5]**2))-1.0/(1+y[5]**2/Zr**2)))-1.0/(Zr*(1+y[5]**2/Zr**2)**(3.0/2))*(math.exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*(math.sin(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))-y[5]/Zr*math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr)))+
y[3]*(math.exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*(-2*y[3])/(2*Zr/k*(1+y[5]**2/Zr**2))*
(math.sin(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))-y[5]/Zr*math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr)))+math.exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*(math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))*2*y[3]*y[5]/(2/k*(Zr**2+y[5]**2))+y[5]/Zr*2*y[3]*y[4]/(2.0/k*(Zr**2+y[5]**2))*math.sin(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))))))*y[2]/(1+y[0]**2+y[1]**2+y[2]**2)**(1.0/2),
0+(y[3]/(Zr*(1+y[5]**2/Zr**2)**(3.0/2))*math.exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*(-2*y[4]/(2*Zr/k*(1+y[5]**2/Zr**2))*(math.sin(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))-y[5]/Zr*math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr)))+2*y[4]*y[5]/(2/k*(Zr**2+y[5]**2))*(math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))+y[5]/Zr*math.sin(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr)))))*y[2]/(1+y[0]**2+y[1]**2+y[2]**2)**(1.0/2),
(y[3]/(Zr*(1+y[5]**2/Zr**2)**(3.0/2))*exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*(k*math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))+k*y[5]/Zr*math.sin(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))))
+(y[0]*((-1.0/2*(1+y[5]**2/Zr**2)**(-3.0/2)*2*y[5]/Zr**2*math.exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))+(1+y[5]**2/Zr**2)**(-1.0/2)*(math.exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*(1+y[5]**2/Zr**2)**(-2.0))*2*y[5]/Zr**2*(y[3]**2+y[4]**2)/(2*Zr/k)*math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))-math.exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*math.sin(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))*(k+(y[3]**2+y[4]**2)*(Zr**2-y[5]**2)/(2.0/k*(Zr**2+y[5]**2))-1.0/(1+y[5]**2/Zr**2)))-1.0/(Zr*(1+y[5]**2/Zr**2)**(3.0/2))*(math.exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*(math.sin(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))-y[5]/Zr*math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr)))+
(math.sin(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))-y[5]/Zr*math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr)))+math.exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*(math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))*2*y[3]*y[5]/(2/k*(Zr**2+y[5]**2))+y[5]/Zr*2*y[3]*y[4]/(2.0/k*(Zr**2+y[5]**2))*math.sin(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))))))-
y[1]*((y[3]/(Zr*(1+y[5]**2/Zr**2)**(3.0/2))*math.exp(-(y[3]**2+y[4]**2)/(2*Zr/k*(1+y[5]**2/Zr**2)))*(-2*y[4]/(2*Zr/k*(1+y[5]**2/Zr**2))*(math.sin(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))-y[5]/Zr*math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr)))+2*y[4]*y[5]/(2/k*(Zr**2+y[5]**2))*(math.cos(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr))+y[5]/Zr*math.sin(k*(y[5]-c*t)+y[5]*(y[3]**2+y[4]**2)/(2/k*(Zr**2+y[5]**2))-math.atan(y[5]/Zr)))))))/(1+y[0]**2+y[1]**2+y[2]**2)**(1.0/2),
y[0]/(1+y[0]**2+y[1]**2+y[2]**2)**(1.0/2),
y[1]/(1+y[0]**2+y[1]**2+y[2]**2)**(1.0/2),
y[2]/(1+y[0]**2+y[1]**2+y[2]**2)**(1.0/2))
y0=[0.0, 0.0, 1.0, 0.0, 0.0, 0.0]
k=30.0
Zr=120.0
c=3e8
t = np.arange(0.0, 1000.0, 0.05) # create time point
# use odeint to solve func
track= odeint(func, y0, t, args=(k, c, Zr))
# plot
from mpl_toolkits.mplot3d import Axes3D
import matplotlib.pyplot as plt
fig = plt.figure()
ax = Axes3D(fig)
ax.plot(track[:,3], track[:,4], track[:,5])
plt.show()
Technology news on Phys.org
Code:
import numpy as np
from pylab import *
import math
return (
k=30.0
Zr=120.0
c=3e8
# plot
fig = plt.figure()
ax = Axes3D(fig)
plt.show()
You're kidding, right? You don't really expect that we're going to look at that huge wad of code, do you?
Mark44 said:
You're kidding, right? You don't really expect that we're going to look at that enormous lump of goop, do you?
Sorry. Actually, just the equations are a little long.
The idea is simple.
import numpy as np
from pylab import *
import math
return (
k=30.0
Zr=120.0
c=3e8
# plot
fig = plt.figure()
ax = Axes3D(fig)
plt.show()
different colors mean 6 equations for y[0], y[1], y[2], y[3], y[4], y[5]
I just want to integrate them and get px, py, pz, x, y, and z. And then use x, y, and z to
draw trajectory of the particle.
import numpy as np
from pylab import *
import mathdef func(y, t, k, c, Zr):
#px, py, pz, x, y, z = y & 的d(px)/dt=y[0]; d(py)/dt=y[1]; d(pz)/dt=y[2]; d(x)/dt=y[3]; d(y)/dt=y[4]; d(z)/dt=y[5]
return (
d(px)/dt,
d(py)/dt,
d(pz)/dt,
d(x)/dt,
d(y)/dt,
d(z)/dt)
k=30.0
Zr=120.0
c=3e8
track= odeint(func, y0, t, args=(k, c, Zr))# plot
fig = plt.figure()
ax = Axes3D(fig)
plt.show()
And the error message?
I want to print track[:,3] (which is x coordinate)
but the output is
lsoda-- at current t (=r1), mxstep (=i1) steps
taken on this call before reaching tout
In above message, I1 = 500
In above message, R1 = 0.4578094279642E-05
Excess work done on this call (perhaps wrong Dfun type).
Run with full_output = 1 to get quantitative information.
[ 0.00000000e+00 -9.26095625e-12 0.00000000e+00 ..., 0.00000000e+00
0.00000000e+00 0.00000000e+00]
And the 3D trajectory is obviously wrong, which should not be a straight line.
no idea, but here's how I've successfully called the ode integrator in one of my python programs:
Code:
result,info = odeint(func,y0, arange(0,tf,dt), args = (I,D),full_output=1)
compared to your:
Code:
the only difference I see is full_output argument and I called the second output argument.
Code:
import numpy as np
from pylab import *
import math
return (
k=30.0
Zr=120.0
c=3e8
# plot
fig = plt.figure()
ax = Axes3D(fig)
plt.show()
Even assembler code is easier to read than this!
I think this should be easier to read.
import numpy as np
from pylab import *
import math
return (
d(px)/dt,
d(py)/dt,
d(pz)/dt,
d(x)/dt,
d(y)/dt,
d(z)/dt)
k=30.0
Zr=120.0
c=3e8
# plot
fig = plt.figure()
ax = Axes3D(fig)
plt.show()
Code:
compared to your:
Code:
thanks for reply.
what does "info" means? and what is usefulness of "full_output=1"?
  • · Replies 16 ·
