Finding the Center of Gravity of a Pizza with a Missing Slice
  • Thread starter Thread starter Honda47
The center of gravity of a circular pizza with a radius R and a circular slice of radius R/2 removed is calculated to have moved from point C to point C' along the x-axis by a distance of R/6. The calculation involves determining the center of mass of the entire pizza and the center of mass of the removed slice. Using the formula Xcom = (m1x1 + m2x2) / (total mass), where the total area is derived from the pizza's area minus the area of the removed slice, leads to the conclusion that the distance from C to C' is indeed R/6.
  • Understanding of center of mass concepts
  • Familiarity with basic calculus and geometry
  • Knowledge of uniform density and thickness in physical objects
  • Ability to apply the formula for center of mass (Xcom)
  • Study the derivation of the center of mass for composite shapes
  • Explore applications of center of mass in physics problems
  • Learn about the implications of uniform density in material science
  • Investigate the effects of removing sections from geometric shapes on their center of mass
Students in physics, engineering professionals, and anyone interested in understanding the principles of center of mass in physical systems.
Honda47
Here is my question I'm not sure even how to come up with the answer:
A circular pizza of radius R has a circular piece of radious R/2 removed from one side. The center of gravity has moved from C to C' along the x axos. Show that the distance from C to C' is R/6. Assume the thickness and density of the pizza are uniform throughout.
If anyone could give me some pointers they would be greatly appreciated.
Find the center of mass of the pizza (in the center, obviously) and then find the center of mass of the removed piece.
Xcom = (m1x1 + m2X2) / (total mass)
If the pizza has density d, then the total area must be R^2*pi - (R/2)^2*pi. This goes in the denominator. Now you simply find the center of mass of the removed piece, which should be (R/2)^2*pi. Multiply this by R/2 (the distance to the center). I hope that helps some.
10K
  • · Replies 36 ·
  • · Replies 16 ·
