Find the equation of the curve
  • Thread starter Thread starter aerin8
    Curve
The discussion revolves around identifying the equation of a curve based on a given sequence of numbers. Participants are tasked with graphing the sequence, finding the equation, and determining a specific term in the sequence.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss graphing the sequence and recognize a pattern in the differences between successive terms. Some express uncertainty about how to derive the equation from the observed pattern.
There is an ongoing exploration of the relationship between the sequence and potential mathematical models, including the possibility of the curve being a parabola. Guidance has been offered regarding the use of difference equations, but no consensus has been reached on the exact nature of the curve or the equation.
Participants are working with a specific sequence and are constrained by the need to derive an equation without explicit instructions or formulas provided. The discussion includes questioning the definitions and characteristics of curves and parabolas.
aerin8
From the given sequence of numbers (11.25, 10, 9.25, 9, 9.25, 10, 11.25, 13, 15.25, 18 ...)
A) Graph the sequence
B) Find the equation of the curve
C) Determine the 100th term of the sequence
I know how to graph the sequence by setting the given numbers as y coordinates and their order as x coordinate but beyond there I'm stuck. Help please!
There is a certain pattern that jumps out here. Look at the difference of successive terms in this sequence.
Also, the second differences are constant.
I can see the pattern but I don't know how to apply it in the equation of the curve. Is there a formula I can plug the data into to find the equation?
is the curve the same thing as a parabola?
The curve might be a parabola. If so, you know where the vertex is.
In case it's not a parabola, there's an area of mathematics called Difference Equations (see http://en.wikipedia.org/wiki/Recurrence_relation) that might be helpful. See especially the section titled "Relationship to difference equations narrowly defined."
