Proof that 1/2 +2/3 + 3/4 does not equal a whole number
  • Thread starter Thread starter Astronamus
    Proof
The discussion revolves around the mathematical exploration of the sum \( \frac{1}{2} + \frac{2}{3} + \frac{3}{4} \) and its relationship to whole numbers. Participants engage in various proofs and hints regarding the properties of series and factorials, touching on topics such as the Harmonic series and perfect squares.
  • One participant presents a summation formula for \( \sum_{j = 1}^{N} \frac{j}{j + 1} \) and suggests it can be expressed in terms of the Harmonic series.
  • Another participant points out a potential error in the sign of a previous contribution and hints at a contradiction arising from clearing denominators in the proof.
  • There is a discussion about the divisibility of factorial sums, with one participant arguing that if \( n \) is prime, then \( n \) must divide \( (n-1)! \), leading to a contradiction.
  • Several participants explore whether the sum of factorials \( \sum_{r=1}^{n} r! \) can ever be a perfect square, with some noting specific cases and others suggesting hints for further exploration.
  • Participants discuss properties of numbers modulo 10 and 3, considering how these properties relate to perfect squares and divisibility.
  • There is a clarification about the relationship between numbers that are congruent modulo 10 and their divisibility by 3, with some participants expressing confusion about the implications of their findings.
Participants do not reach a consensus on the proofs or properties discussed. Multiple competing views and unresolved questions remain regarding the nature of the sums and their relationships to whole numbers and perfect squares.
Some arguments depend on specific assumptions about the properties of numbers and their divisibility, which are not universally agreed upon. The discussion includes hints and suggestions rather than definitive proofs.
Astronamus
I am deleting
Does this help?
[tex]\sum_{j = 1}^{N} \frac {j}{j + 1} = \sum_{j = 1}^{N} \left( 1 - \frac {1}{j + 1}\right) = N - \sum_{j = 1}^{N} \frac {1}{j + 1}[/tex]
Minor quibble-Tide you lost a negative sign.
Tide has reduced this nicely to showing any the Harmonic series never hits an integer. This might be tough to prove so I'll kick out a hint.
Let 2^k be the largest power of 2 less than or equal to N, so 2^k<=N<2^k+1. Assume the sum is an integer. Clear the denominators carefully so every term becomes an integer, except the 1/2^k term. This gives a contradiction.
I'll leave it to you how to clear them 'carefully', but seeing how to do this for the first few values of N might help.
if you clear denominators you see that n! must divide the top. It follows for example that n must divide (n-1)! which is impossible say, if n is prime. If not, and p is the largest prime number less than n, it follows again that p must divide some number between p+1 and n. I.e. n must be at least 2p. But this contradicts the fact that there must be another prime between p and 2p, hence another between p and n.
This is kind of related, is:
[tex]\sum_{r=1}^{n} r![/tex]
ever a perfect square? I know this is true for n=1 and n=3, but what about in general?
I'd like hints only, please. :smile:
I'd probably pick some useful number and look at things mod that number. for it is divisible by 3 for n>1, so it must be WHAT if it is a square?
It must be in the form 3(n^2) or in the form 3^(2n+1)?
For n>4, the last digit is always '3', so it will never be a perfect square.
I swear I was just thinking the same thing!
m! where m>4 always ends in zero. So when n>4, we have 10p+(4!+3!+2!+1!)=10p+30+3=10q+3, but I really didn't know that if a number ends in 3 it's a perfect square.
just work out the squares of the residues mod 10, which is what i meant by considering a suitable mod thing
and if 3 divides N and N is a square then 9 divides N is what I meant
matt grime said:
just work out the squares of the residues mod 10, which is waht i meant by considering a suitable mod thing
Wow... That's brilliant.
Well done!
For the sake of curiosity...
What you're saying is:
if N>3 and N = 0 (mod 3), then N = 0 (mod 9).
Right?
Can we generalize this to:
if N>3^n and N = 0 (mod 3), then N = 0 (mod 3^{n+1})?
This is realiant on N being a square, you realize, and nothing to do with N being greater than some power of three, nor for that matter is it to do with 3.
Let N be the n'th power of q where q is an integer. Write q as the product of primes, now, what is the decomposition of N relative to q?
For example, let n=3 so we#re considering cubes. What are some cubes? 8, 27, 216. How may times do 2 and 3 occur each decomposition? it's always a multiple of n isn't it?
I know this might sound naive, but why is that?
Wait, nevermind... I figured it out. :smile:
So, to sum up, if q divides p^n then so does q^n?
Thanks for all your help matt.
Did you write out q as a product of primes? Raise it to the power n? What do you get?
for instance if q=12=2^2.3, then q^3= 2^^.3^3 doesn't it?
in response to your last corrected qusetion, only if the divisor is a prime, it is one of the equivalent criteria for being prime (in the integers)
Yeah, naturally.
Thanks again.
daster said:
...but I really didn't know that if a number ends in 3 it's a perfect square.
And it is not!
As I had said, if a number ends in 3, it is not a perfect square.
There is no n>4 which satisfies your equation.
Rogerio said:
And it is not!
Yes, sorry, that's what I meant. :smile:
matt,
I have one more question about your proof.
S = 33 (mod 10), but does S really need to be divisible by 3? 43 = 33 (mod 10), but 43 isn't divisible by 3.
what proof? I didn't say that I'd proved it, I offered two things for you to think about that might prove it. One of them does more easily than the other. I've no idea if the sum of the first r!'s is not divisible by 9 or not, but that seems a reasonable thing to consider. Divisbility by 3 and the modulo 10 bit are completely unrelated. The mod 10 bit proves it straightforwardly.
And I've no idea what's puzzling you in your question. Of course there's no reason for two numbers in the equivalence class of 3 mod 10 to both be divisible by 3, there's no reason for either of them to be divisible by 10. IF they are both divisible by 3, so is their difference, which, by definition, is also divislbe by 10, and hence by 30. And?
Oh, sorry. I misread what you posted. I know that the mod 10 bit proves (since 33 isn't a square mod 10), but I thought you'd approached it from a different angle.
I had. A little check, which I intended you to do demonstrates the div by 9 thing doesn't actually help.
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 17 ·
