New Reply
Ohmic heating to heat hockey stick blade glue
Share Thread Thread Tools
Nov7-11, 08:43 PM   #1
I am an ME, looking for resources or advice to assist my team in designing an ohmic heat source. The device will transport hot air with a small fan. We will be utilizing a 120VDC power source. This heater must produce temperatures in the range of 500-1000F. We are anticipating using a wire geometry similar to the resistance wire in a blow dryer or heat gun. Are there any standards for wire gauge/cross section, or suggested wire materials to achieve maximum heat transfer?
Any advice and/or external resources would be appreciated.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
>> Company pioneering new types of material for 3-D printer 'ink'
>> Student-built innovations to help improve and save lives
Nov8-11, 11:18 AM   #2
Mentor
Quote by coolbackyard View Post
Welcome to the PF.
Nichrome wire is commonly used in heater elements:
http://en.wikipedia.org/wiki/Nichrome_wire
Is the reason that you can't use a standard heater because of the unusual geometry of the blade and stick?
Nov8-11, 03:58 PM   #3
Recognitions:
Gold Membership Gold Member
A hot air gun (or several) blown into an appropriately shaped tube / enclosure with thermal insulation? Top and bottom halves of the enclosure could be clipped together or hinged.
You really don't want to get involved with home made mains heating elements. It's not a trivial job. For those temperatures you would need good refractory supports for the heating elements and good electrical safety. Use an off the shelf heat source and concentrate on getting your enclosure the right size and shape and with the right insulation.
Nov8-11, 05:51 PM   #4
Excuse me, I meant 120VAC source. We will not be building a prototype, this is just for the design phase.
Nov9-11, 03:49 AM   #5
Recognitions:
For design or development I should have thought you'n need to establish the power needed. Much easier with off the shelf heaters. I would think.
New Reply
Tags
heating, power, resistance, temperature and heat, wire
Thread Tools
Similar Threads for: Ohmic heating to heat hockey stick blade glue
Thread Forum Replies
Resistance heater for hockey blade Mechanical Engineering 2
Myth Busters - Should I lick or use a glue stick? General Discussion 11
