Why are the natural frequencies of a clamped-clamped beam smaller than usual?
  • Thread starter Thread starter jeffziggy
    Fem Weird
The discussion focuses on the calculation of natural frequencies for a clamped-clamped beam using Matlab. The user, Jeff, discovered that the frequencies obtained were consistently smaller than expected, specifically by a factor of N², where N represents the number of elements in the model. This discrepancy arises because the global mass is proportional to the length of the beam, while the global stiffness is inversely proportional to the cube of the length, leading to a frequency relationship of 1/l². The solution involves recognizing the impact of the number of elements on the beam's effective length.
  • Understanding of finite element analysis (FEA)
  • Familiarity with Matlab programming and the eig() function
  • Knowledge of beam theory and natural frequency calculations
  • Basic concepts of mass and stiffness matrices in structural analysis
  • Study the principles of finite element modeling in structural analysis
  • Learn about the derivation of natural frequencies in clamped beams
  • Explore advanced Matlab functions for structural dynamics
  • Investigate the effects of boundary conditions on frequency calculations
Mechanical engineers, structural analysts, and researchers involved in vibration analysis and finite element modeling of beams.
jeffziggy
Hello,
I recently used Matlab to find the natural frequencies of a clamped-clamped beam. It was fairly simple, as I construct the global mass and stiffness matrices. Then it's just a matter of using the eig() function. (For sake of simplicity I put beam properties all to 1.)
When I choose how many elements (lets call it N) to use, it seems to give me natural frequencies which, seem to be smaller than usual. I somehow stumbled upon the fact that these frequencies are the literature values I have divided by N^2.
Anyone got any ideas as why this is so? Here is my code. Thanks! Edit: For example when N = 10, my first natural frequency is 0.2237 when the exact value is 22.37.
Jeff
Code:
syms y;
syms z;
area = 1;
L = 1;
p = 1;
E = 1;
Ig = 1;
n = 10; %number of elements
if n == 0
stop
end
size = 4+((n-1)*2);
%define global matrices
Mg = zeros(size);
Kg = zeros(size);
%beam function
A = [1 0 0 0 ; 0 1 0 0 ; 1 L L^2 L^3 ; 0 1 2*L 3*L^2];
Ainv = inv(A);
Aitrans = transpose(Ainv);
Yh = [1 ; y ; y^2 ; y^3];
Ya = [1 ; y];
Ydotdot = diff(diff(Yh));%Solving for Mass matrix (kinetic energy)
prod1 = Yh*transpose(Yh);
M = p*area*Aitrans*int(prod1, y, 0, L)*Ainv;
%solving for stiffness matrix (potential energy)
K = (E*Ig)*Aitrans*int(Ydotdot*transpose(Ydotdot), y, 0, L)*Ainv;
%creating the global mass matrix
Mg(1:4, 1:4) = M(1:4, 1:4);
Kg(1:4, 1:4) = K(1:4, 1:4);
if n > 1
i = 1;
j = 1;
    for i=1:n-1
    Mg(j+2:j+5, j+2:j+5) = Mg(j+2:j+5, j+2:j+5) + M(1:4, 1:4);
    Kg(j+2:j+5, j+2:j+5) = Kg(j+2:j+5, j+2:j+5) + K(1:4, 1:4);
    j = j+2;
    end
end
%delete rows/columns based on clamped ends (boundary conditions)
Mg(size,:) = [];
Mg(size-1,:) = [];
Mg(:,size) = [];
Mg(:,size-1) = [];
Mg(:,1) = [];
Mg(:,1) = [];
Mg(1,:) = [];
Mg(1,:) = [];Kg(size,:) = [];
Kg(size-1,:) = [];
Kg(:,size) = [];
Kg(:,size-1) = [];
Kg(:,1) = [];
Kg(:,1) = [];
Kg(1,:) = [];
Kg(1,:) = [];eigs = eig(Kg,Mg);
sqrt(eigs)
I haven't checked every line of the code, but I think you have each element of length 1, so the length of your beam depends on the number of elements in the model.
If the length of the beam is [itex]l[/itex], the global mass is proportional to [itex]l[/itex] and the global stiffness proportional to [itex]1/l^3[/itex], so the frequences would be proportional to [itex]\sqrt{k/m} = 1/l^2[/itex].
That was exactly it! Thank you kind sir!
Jeff
  • · Replies 21 ·
  • · Replies 40 ·
  • · Replies 18 ·
