Proving Convergence of the Sum for Real Parameter a in (-1,1)"
  • Thread starter Thread starter twoflower
    Approach
The discussion centers on proving the convergence of the series \(\sum_{n=1}^{\infty} \frac{a^{n}}{1+a^{n}}\) for real parameter \(a\) within the interval (-1, 1). The user successfully applies d'Alembert's criterion, demonstrating that the limit \(\lim_{n \rightarrow \infty} \frac{a_{n+1}}{a_{n}} = 0\) confirms convergence for \(a < 1\). Despite an initial miscalculation regarding the limit, the conclusion remains valid, affirming that the series converges when \(a\) is in the specified interval.
  • Understanding of series convergence and limits
  • Familiarity with d'Alembert's ratio test
  • Basic knowledge of real analysis
  • Proficiency in manipulating limits and algebraic expressions
  • Study the application of d'Alembert's criterion in various series
  • Explore other convergence tests such as the Ratio Test and Root Test
  • Investigate the behavior of series with parameters outside the interval (-1, 1)
  • Learn about uniform convergence and its implications in real analysis
Mathematicians, students of real analysis, and anyone interested in series convergence and limit evaluation techniques.
twoflower
Hi all,
my task is to solve the convergence of the sum in dependence to the parameter a real.
[tex] \sum_{n=1}^{\infty} \frac{a^{n}}{1+a^{n}}[/tex]
I did it this way:
First I found out that if the sum converges, a will have to be in interval (-1, 1). So how to prove that for these values of parameter the sum converges?
Let's try d'Alembert's criterion, which tells us this:
[tex] \lim_{n \rightarrow \infty} \frac{a_{n+1}}{a_{n}} < 1 \Rightarrow \sum a_{n}{} is convergent[/tex]
So:
[tex] \lim_{n \rightarrow \infty} \frac{a^{n+1}}{1+a^{n+1}} : \frac{a^{n}}{1+a^{n}} = [/tex]
[tex] \lim_{n \rightarrow \infty} \frac {a^{n+1}.(1+a^{n})}{a^{n}.(1+a^{n+1})} = [/tex]
[tex] \lim_{n \rightarrow \infty} \frac {a.(1+a^{n})}{1+a.a^{n}} = [/tex]
[tex] \lim_{n \rightarrow \infty} \frac {a}{a^{n+1} + 1} + \lim_{n \rightarrow \infty} \frac{a^{n+1}}{a^{n+1} + 1}[/tex]
[tex] \lim_{n \rightarrow \infty} \frac {a}{a^{n+1} + 1} = \lim_{n \rightarrow \infty} \frac { \frac{a}{a}}{a^{n} + \frac{1}{a}} = \frac{1}{0 + \frac{1}{a}} = 0[/tex]
[tex] \lim_{n \rightarrow \infty} \frac {a^{n+1}}{a^{n+1} + 1} = \lim_{n \rightarrow \infty} \frac {1}{1 + \frac{1}{a^{n+1}}} = 0[/tex]
Thus
[tex] \lim_{n \rightarrow \infty} \frac {a^{n+1}}{a^{n+1} + 1} : \frac{a^{n}}{1+a^{n}} = 0 + 0 = 0[/tex]
This way I proved the convergence for a in (-1, 1)
Is it ok?
Thank you for your comments.
That limit is incorrect, the expression goes to "a", not to 0.
However, since a<1, convergence is achieved.
You're right, I didn't take into account that a is constant.
  • · Replies 21 ·
