What is the physical meaning of [H,ρ ]=0 for a stationary state?
  • Context: Graduate
  • Thread starter Thread starter jiadong
    Physical State
The discussion revolves around the physical meaning of the commutation relation [H, ρ] = 0 in the context of stationary states in quantum mechanics. Participants explore the implications of this relation for the density operator ρ and the Hamiltonian H, addressing both theoretical and conceptual aspects.
  • Some participants note that if ρ is the density operator of an ensemble, the relation [H, ρ] = 0 implies that H and ρ can share the same eigenvectors.
  • One participant discusses the diagonalization of H and ρ, suggesting that the eigenstates that can be diagonalized together are generally a subset of the eigenstates of H.
  • Another participant points out that a diagonal density matrix corresponds to a completely incoherent mixture, indicating that the eigenvectors of ρ represent the constituents of this mixture.
  • Some participants express uncertainty about the specific characteristics of ρ when [H, ρ] = 0, with one participant apologizing for their confusion regarding the physical meaning of the relation.
  • Several participants reference the von Neumann equation, stating that for a stationary state, the statistical operator must not explicitly depend on time, leading to the conclusion that [ρ, H] = 0 indicates a relationship with conserved quantities.
  • One participant draws a parallel between the von Neumann equation and Liouville's equation in statistical mechanics, suggesting a similar role in quantum statistical mechanics.
Participants express a range of interpretations regarding the implications of [H, ρ] = 0, with some agreeing on the relationship between the eigenvectors of H and ρ, while others remain uncertain about the physical meaning and characteristics of ρ in this context. The discussion reflects multiple competing views and unresolved questions.
Some limitations include the dependence on the definitions of the operators involved, as well as the assumptions made regarding the eigenstates and their relationships. Unresolved mathematical steps and the specific characteristics of the density operator in this context are also noted.
jiadong
If ρ is the desity operator of a ensemble.
We get (ih/2π) ∂ρ/∂ t = [H,ρ ].
for a stationary state [H,ρ ]=0 . So H and ρ can share the same eigenvectors. Can someone explain what does this mean?
:smile:
let suppose you have of H:
[itex]\hat{H}|E_i\rangle=E_{H,i}|E_i\rangle[/itex]
If you can diagonalize H and rho together
there is no reason to think that the set of [itex]|E_i\rangle[/itex] that can be diagonalized at the same time with H are ALL the [itex]|E_i\rangle[/itex] that are diagonal for [itex]\hat{H}[/itex]. in general the eigenstates in common is a subset of the eigenstates of H.
But let consider only the sub set of eigenstates of H that are also eigenstates of rho, you have
[itex]\hat{\rho}|E_i\rangle=E_{p,i}|E_i\rangle[/itex]
and so you can write rho as
[itex]\hat{\rho}=\Sigma_i \lambda_i |E_i\rangle\langle E_i|[/itex]
that is the representation of your rho in the eigenstates of hamiltonian.
The density matrix being diagonal corresponds to a completely incoherent mixture. So the eigenvectors of the density matrix are the constituents of this mixture.
But the expression
is of the same form to the defination of desity operator in a mixture state. I still don't know the specail characteristics of thie kind of rho. I am sorry, I am so stupid to understand the physical mean of [H, ρ ]=0.
Thank you for your reply.
Thank you, Kith! You mean that if [H,ρ]=0,thenthe eigenvectors of the ρ are the constituents of a incoherent mixture.
The complete equation of motion for the Statistical Operator is the von Neumann equation,
[tex]\left (\frac{\partial \hat{\rho}}{\partial t} \right )_{\text{exp}} + \frac{1}{\mathrm{i} \hbar} [\hat{\rho},\hat{H}]=0.[/tex]
Since a stationary state is defined as one for which the Statistical Operator is not explicitly dependent on time, for this case you arrive at the simplified equation
[tex][\hat{\rho},\hat{H}]=0.[/tex]
This means that for a stationary (or equilibrium) state, the Statistical Operator of the system must be a function of the conserved quantities and not explicitly dependent on time.
Now I see, the equation
plays similar role in quantum statistical mechanics as the Liuville's Equation does in Statistical mechanics.
  • · Replies 23 ·
  • · Replies 21 ·
