Period of oscillation (potential energy equation given)
The problem involves determining the period of small oscillations for a particle whose potential energy is defined by the equation U(x) = U0(1-cos(ax)). The context is centered around oscillatory motion and the characteristics of potential energy functions.
  • Participants discuss the equilibrium position and the nature of the forces involved. There are questions regarding the integration of the potential energy function and its relevance to forced oscillations. Some participants reference conditions for simple harmonic motion and suggest using approximations for small angles.
The discussion is active, with participants exploring different interpretations of the potential energy function and its implications for oscillatory motion. Some guidance has been offered regarding the conditions for simple harmonic motion, while additional questions about a second part of the problem have been raised, indicating a multi-faceted exploration of the topic.
Participants note that the problem consists of two parts, with the second part introducing a different potential energy equation, U(x) = a/x² - b/x, which raises questions about forming its differential equation. There is an acknowledgment of the need for further clarification on the nature of the oscillations described.
sodaboy7
Let the potential energy of particle depend upon coordinate x as:
U(x) = U0(1-cos(ax)). Where "U0" and "a" are constants. Find the period of small oscillations that particle performs about its equilibrium position.
2. Given Answer
T = 2∏√(m/a2U0)
It can be seen from the equation that equilibrium will be at x = 0, where forces acting are zero. Also after integrating the equation with dx, it is seen that the motion is relevant to forced oscillations.
U(x) is the potential function. Why do you integrate it?
The motion is not forced oscillation. For that, an external time dependent force is needed.
ehild
There a two sufficient conditions to prove something is simple harmonic oscillator
F = -kx
or
Etotal = [itex]\frac{1}{2}[/itex]Av2+[itex]\frac{1}{2}[/itex]Bq2. Where A and B are some constants and, q is some coordinate (in your case ax). Then the period is T = 2π√(A/B) Also since it says small oscillations, I would use the small angle approximation for cosine.
Thanks for that. But this questions has two parts which I didn't mention.
The part-2 of the problem has the equation:
U(x)= a/x2 - b/x
How to deal with this one ?
I mean in above equation x has powers -2 and -1. So how to form its differential equation?
Well assuming the kinetic energy is of the form: [itex]\frac{1}{2}[/itex]mv2, the the period for small oscillations is 2π√(k/m) where, k is the second derivative of the potential energy function evaluated at the equilibrium position (you might have to take the limit as it goes to the equilibrium position in this case...)
