| New Reply |
How to measure charging of Cockcroft Walton Multipliers? |
Share Thread | Thread Tools |
| Nov10-11, 12:38 AM | #1 |
How do you measure the voltage of a cockcroft walton multiplier over time to observe the charging behavior? Does measuring with oscilloscopes discharge the capacitor hence you cant observe the charging or not?
| Nov10-11, 01:10 AM | #2 |
Recognitions:
The oscilloscope doesn't impose much loading on the circuit. You are wanting to observe the actual pumping up? That will be a short term transitory waveform. Using a CRO with differential inputs might be handy, if you wish to observe all waveforms around the circuit.
| Nov11-11, 02:56 PM | #3 |
Yeah. Ideally I'd like to see the oscillation with amplitude offset increasing as time goes on.
Right now I have a simple half wave multi stage multiplier set up. I can measure the rectification part, so the sine wave only goes to the positive and not negative, but I dont see the amplitude increase so that the dc offset is always zero essentially. It could be my driving frequency isnt correct perhaps? Rhetorical I guess but is it better to measure the voltage across the capacitor at the highest stage or measure the potential relative to ground. |
| Nov11-11, 04:40 PM | #4 |
Recognitions:
How to measure charging of Cockcroft Walton Multipliers?Can you post your circuit schematic? |
| New Reply |
| Thread Tools | |
Similar Threads for: How to measure charging of Cockcroft Walton Multipliers?
| Voltage limiter for Cockroft/ walton cap charger | Electrical Engineering | 0 | ||
| Cockroft Walton Voltage Multiplier Problems | Electrical Engineering | 1 | ||
| Cockroft Walton Capacitor charging circuit. | Electrical Engineering | 13 | ||
| I want a Cockroft Walton multipler design values | Electrical Engineering | 0 | ||
| Cockroft-Walton question. | Electrical Engineering | 7 | ||
