New Reply
Does temperature in static particles increase due to gravity?
Share Thread
Nov10-11, 12:36 PM   #1
Hello, I was wondering if particles that have a set position such as for example particles within the earth's core would experience a temperature gain due to gravity.
If kinetic energy is applied to the particles in the air due to gravity, then kinetic energy should also be applied to particles deep inside the earth right? But because the particles don't really have anywhere to go I would expect this kinetic energy to be transformed into temperature.
If so, how do these gains in temperature differ based on distance to the core? The total force of gravity would be higher in the core because its average distance to other particles would be lower, but the forces do balance out completely at the exact core because it would come from all sides. How would these forces translate into thermal energy?
PhysOrg.com physics news on PhysOrg.com
>> Cheap, color, holographic video: Better holographic video displays
>> First entanglement between light and optical atomic coherence
>> EUROnu project recommends building Neutrino Factory
Nov10-11, 10:53 PM   #2
I think you are confusing gravity, density and pressure. The net central force of gravity decreases as you move closer to the center of the earth, but the pressure, density and temperature all increase. How exactly they do this depends on how far down you go, what the local material composition is, and what it's equation of state is.
New Reply
Similar discussions for: Does temperature in static particles increase due to gravity?
Thread Forum Replies
Increase in entropy without change in temperature Classical Physics 5
Does resistance go up or down with an increase in temperature? Electrical Engineering 6
Temperature vs area increase Introductory Physics Homework 3
Temperature Increase of a Wire Electrical Engineering 7
How to increase the temperature of the ball mill in the lab? Materials & Chemical Engineering 2
