Heat capacity / letent heat question
The discussion revolves around a heat transfer problem involving an ice cube and water, specifically focusing on calculating the final temperature when an ice cube at -8 degrees Celsius is placed in water at 95 degrees Celsius. The problem involves concepts of heat capacity and latent heat.
  • Participants discuss the need to account for multiple temperature changes (delta t) for both the ice and the water, including the latent heat of fusion. There is an exploration of how to set up the equations for heat transfer.
Participants are actively engaging in formulating the problem, with some providing calculations for the heat absorbed by the ice and the heat given off by the water. There is a recognition of the need to equate these heats to find the final temperature, and some participants express uncertainty about specific steps in the process.
There is a mention of ignoring heat transfer to the cup and surroundings, and participants are working within the constraints of the problem as presented in the homework statement.
blarginsnarf
An ice cube of mass 40g is transferred directly from the freezer where it is at -8 CELSIUS to a cup containing 120g of water at 95 degrees CELSIUS. Calculate the final temperature of water. Ignore any heat transfer to the cup or its surroundings
tf = ti + delta t
Is there a possibility elimination/substitution is involved? :S
0.04 (2.1 x 10^3)(delta t) + (0.12)(4.18 x 10^3)(delta t)
I solved for it and its wrong. The teacher gave us the answer, but not how to solve it so we can check it later. The answer is 50 degrees Celsius. Can someone show me how they solved it? :S
Welcome to PF, blarginsnarf! :smile:
tf = ti + delta t
You are skipping a few steps here.
In particular you have not included the latent heat.
Let's start with your "delta t".
There is not just one "delta t" here, but there are 3 delta-t's.
First you have the delta t for the ice from its initial temperature to the melting point.
Second you have the delta t for the ice from the melting point to the as yet unknown final temperature.
And third you have the delta t for the hot water from its initial temperature to the unknown final temperature.
Can you write these 3 delta-t's in formula form?
Alright, this is what I got:
1. delta t= 0 - (- 8)
delta t = 8
2. delta t = tf - 0
3. delta t = tf - 95
How's that? :S
Good! :)
What would be the heat absorbed by the ice (in formula form) to bring it first to the melting point, then melt it, and then bring it up to the final temperature?
I like Serena said:
Good! :)
Well according to my textbook, the heat capacity of ice is: 2.1 x 10 ^ 3
So... I did this: What would be the heat absorbed by the ice (in formula form) to bring it first to the melting point:
q = mct
q = 0.04 x 2.1 x 10 ^ 3 x 8
q = 672 J
then melt it:
Latent heat formula:
Latent heat of fusion for water in my textbook = 3.4 x 10 ^ 5
Qf = mlf
Qf = 0.04(3.4 x 10 ^ 5)
Qf = 13600 J
and then bring it up to the final temperature?:
I'm not sure at all :S
What I'm assuming: mass of ice + mass of water * latent heat of fusion for water? :S
q = mct
q = 672 J
Yep! :smile:
blarginsnarf said:
then melt it:
Qf = mlf
Qf = 13600 J
Good!
That would be, with a heat capacity of water of 4.2 x 10 ^ 3:
q = mcΔt
q = 0.04 x 4.2 x 10 ^ 3 x (tf - 0)
Huh? I don't understand what you're saying here.
You're adding a mass to a heat? :confused:
Next can you tell me what the heat given off by the hot water is (in formula form)?
The sum of the heats that the ice absorbs has to be equal to the heat the hot water gives off.
Can you set up the equation for that?
I like Serena said:
Yep! :smile:
Good!
q = mcΔt
Alright, so 672 + 13600 + 168tf
= 14272 + 168tf? :s I don't know tfNext can you tell me what the heat given off by the hot water is (in formula form)?
I THINK it's like this:
Q = MCT
Q = 0.12 x 4.2 x 10 ^ 3 x(tf - 95)
Q = -46368 + 504tf
How's that? :D
What's not to know?
That is right!
Q = MCT
Q = -46368 + 504tf
How's that? :D
Great!
Now the heat absorbed by the ice must be equal to the heat given off by the hot water.
Can you set them equal to each other (mind the minus sign) and solve for tf?
Oh my gosh, I just solved it on paper. Thank you so much! You are a legend!
Thanx! :redface:
