Entropy related questions - Reversible or Irreversible?
In summary, the melting of the ice in the given scenario is irreversible because an infinitesimal change in temperature of the room would not reverse the process. The net entropy change of the system during this process is consistent with the answer of 1253J/K. As for the second question, the change in entropy is 33.3J/K and the process is irreversible because the temperature stays constant and the work done by the gas is the same as the work done on the surroundings.
JustinLiang
81
Entropy related questions -- Reversible or Irreversible?
A 15.0kg block of ice at 0C melts to liquid water at 0C inside a large room that has a temperature of 20C. Treat the ice and the room as an isolated system, assume that the room is large enough for its temperature change to be ignored. a) Is the melting of the ice reversible or irreversible? Explain, using simple physical reasoning without resorting to any equations.
b) Find the net entropy change of the system during this process. Explain whether or not this result is consistent with your answer to part a.
I initially said the process is reversible because it stays in thermal equilibrium (0C), but the answer key says it's irreversible. As for the entropy I got 1253J/K which is the right answer.
Could someone please explain to me the theory behind entropy and reversible/irreversible processes?
Thanks!
A reversible process is one in which the direction of the process can be reversed by an infinitessimal change in conditions.
If the room was kept at temperature 0C+δT/2 where δT was an arbitrarily small temperature difference, a change in temperature of δT to 0C - δT/2 would cause the ice to freeze instead of melt. So in that case, the melting of the ice would be reversible (but it would also take an infinitely long time to occur).
But here the room is at 20C. An infinitessimal change in room temperature would not put it below 0C so it would not cause the water to freeze - the ice would still melt. So it is not reversible.
AM
AM
Ah I see, so the temperature of the room must equal the ice to be in thermal equilibrium and be reversible.Edit: Okay what about this question, it is isothermal (same temperature) so I don't see how it is irreversible?
Also A 10L gas tank containing 3.2 moles of ideal He gas at 20C is placed inside a completely evacuated, insulated bell jar of volume 35L. A small hole in the tank allows the He to leak out into the jar until the gas reaches a final equilibrium state with no more leakage. A) what is the change in entropy of the system due to the leaking of the gas? b) is the process reversible or irresversible? How do you know?
^ The ans to the change in entropy is 33.3J/K, which is what I got but how do you know if the process is reversible or not with relation to entropy? The temperature stays in the gas and surroundings are the same; the work the gas does is the same as the work done on the surroundings. So wouldn't this mean the process is irreversible?
1. What is entropy?
Entropy is a measure of the disorder or randomness in a system. It is a thermodynamic property that describes the amount of energy that is unavailable for work in a system.
2. How is entropy related to reversibility?
In reversible processes, the entropy remains constant because the system is in equilibrium and there is no net change in disorder. In irreversible processes, the entropy increases because there is a net increase in disorder as the system moves away from equilibrium.
3. Can entropy be reversed?
No, entropy cannot be reversed. The second law of thermodynamics states that the entropy of a closed system always increases over time, and it can never decrease spontaneously.
4. What is an example of a reversible process?
A reversible process is one where the system can be returned to its original state by reversing the direction of the process without affecting the surroundings. An example of this is a pendulum swinging back and forth, where the energy is constantly exchanged between kinetic and potential energy without any net change in entropy.
5. How does entropy relate to the arrow of time?
The increase in entropy over time is directly related to the arrow of time. As entropy increases, the system becomes more disordered, and it becomes increasingly difficult to reverse the process and return to the previous state. This is why time is considered to have a direction, from the past to the future.
  • Classical Physics
  • Other Physics Topics
