| New Reply |
non-linear differential equation |
Share Thread | Thread Tools |
| Nov13-11, 06:11 PM | #1 |
The original equation is:
V'' - k*V^-1/2 = 0 I then said u = V' therefore u' = u(du/dV) so the new equation is : u(du/dV) = V^-1/2*k Im a little rusty on separation of variables but I got a u in the final answer which means I have to integrate again since I need the final answer in terms of V. The goal is to prove k is proportional to V^3/2 Am i doing this right? |
| Nov14-11, 05:12 AM | #2 |
That's a common way to do it and you're left with:
[tex]u^2=4k\sqrt{v}+c[/tex] or: [tex]\left(\frac{dv}{dt}\right)^2=4k\sqrt{v}+c[/tex] taking square roots, separate variable again and get: [tex]\frac{dv}{\sqrt{4k\sqrt{v}+c}}=\pm dt[/tex] That however looks kinda' messy to integrate although Mathematica gives a nice expression for the left side but then you get an implicit expression for v in terms of t: [tex]g(v)=\pm(t+c_2)[/tex] which is not solvable explicitly for v(t). Doesn't look like it anyway. |
| New Reply |
| Thread Tools | |
Similar Threads for: non-linear differential equation
| Non-linear Schrodinger Equation (Differential Equation) | Differential Equations | 10 | ||
| Non-linear differential equation | Calculus & Beyond Homework | 1 | ||
| linear differential equation? | Differential Equations | 3 | ||
| Linear differential equation | Calculus & Beyond Homework | 1 | ||
| The difference between linear and non linear differential equation | Differential Equations | 2 | ||
