A conceptual question regarding collision/conservation of energy.
  • Thread starter Thread starter lillybeans
    Conceptual Energy
The discussion revolves around a conceptual question regarding the dynamics of a bullet striking a block connected to a spring, specifically focusing on energy conservation and the timing of spring compression during the impact.
  • The original poster explores the implications of different scenarios regarding the timing of spring compression in relation to the bullet's passage through the block. Some participants discuss the assumptions made in collision problems, particularly the instantaneous nature of collisions and the effects on energy transfer.
Participants have engaged in clarifying the assumptions surrounding the collision and the subsequent energy transfer to the spring. There is acknowledgment of the complexities involved in modeling the interaction during the impact, with some guidance provided on how to approach the problem under different assumptions.
Participants note that the problem cannot be solved without additional details about the interaction between the bullet and the block, particularly if the collision is not treated as instantaneous. There is also mention of scenarios where the time of interaction might be relevant.
lillybeans
Say there's the following situation:
A bullet with some velocity strikes a block connected to a spring. The bullet passes right through the block and the spring is compressed by x cm to the right of the block after the impact. Some internal energy is lost due to deformation of the block while bullet passes through it.
Because the question states "compressed AFTER the impact", i was able to assume that the only energy being converted into spring energy is the kinetic energy of the block (When it begins to compress when the bullet has already exited the block), so I solved the problem.
HOWEVER, WHAT IF the question had stated "the block compresses the spring DURING the impact", in other words, it compresses WHILE the bullet is passing through the block? Then would the spring energy come from BOTH the kinetic energy of the block and some of the kinetic energy of the bullet while it is moving through the block?
Good question. But the usual assumption when treating collision problems is that the collision happens instantaneously, that is so fast, that only the velocities change during the impact, nothing else. Of course, this is not true, the bullet needs some time to traverse the block, pushing material aside along its path, initialising reversible and irreversible effects on the block and on itself: exciting elastic waves, producing heat, sound, melting some material...
Ignoring the spring during collision, and treating compression of the spring by the block when the bullet left - it is a correct approximation.
The problem can not be solved otherwise, you would need to calculate the motion both the bullet and block during the impact, and for that you would need details of the interaction between bullet and block.
ehild
ehild
Thank you so much! That was an excellent explanation. May I ask further that if the situation had been "bullet strikes block and bounces back (elastic)", then is it also valid for me to assume that the block starts to move AFTER the bullet starts to bounce back? So I would ignore the spring's compression at the instant where the block-bullet moves together during the collision?
Lilly
Lilly
Exactly. Ignore that short time when they move together, as you do not know how long it is.
There are some problems, when the time of interaction is given or can be computed - but you would notice if that is the case.
ehild
  • · Replies 25 ·
