Homemade Dynomometer for 1HP Engine
  • Thread starter Thread starter tomgwill98
    Engine Homemade
The discussion centers on building a homemade dynamometer for a 1HP engine using an alternator or DC generator for braking. The user plans to measure torque by varying the load on the alternator or generator, which will decrease RPM, and then use a data logger to plot torque versus RPM to calculate power. The conversation confirms that it is feasible to wire the load in parallel to the supply and suggests using a Ford Sierra alternator or considering a DC generator for better torque measurement.
  • Basic understanding of electrical circuits and load management
  • Familiarity with alternator and DC generator operation
  • Knowledge of torque measurement techniques
  • Experience with data logging and power calculation methods
  • Research how to wire an alternator for load testing
  • Learn about torque measurement using a DC generator
  • Explore data logging techniques for engine performance analysis
  • Investigate methods for calculating alternator efficiency
This discussion is beneficial for hobbyists, engineers, and mechanics interested in building custom dynamometers, as well as those looking to measure and analyze engine performance effectively.
tomgwill98
Hi guys.
I'm building a dynomometer for a 1hp engine. I plan to use something like an alternator or a dc generator to do the braking. I will mount the alternator or generator so it is free to rotate around the shaft and measure the force at a distance to get the torque.
The idea is to vary the load on the alternator or generator to increase the amount of torque needed to turn it (therefore RPM will decrease), then use a data logger to plot torque vs RPM and thus calculate power.
My electrical knowledge is limited. Is it possible to configure an alternator or generator (capable of the same/more power of the tested engine) to work in this way? i.e. increasing the load on the alternator/generator to increase the torque required to turn it? If so, how exactly would it be wired?
Sure. Get 100 ten watt light bulbs. Wire these in parallel to your supply. Switch them on individually. Then, you can apply whatever load you wish! It's a simplistic view but you get the idea, hopefully.
You can actually calculate your power by measuring the current going through this circuit, and the voltage at your supply. If you can estimate (or calculate) your alternator efficiency, you know the power your engine is providing.
Cheers for the reply, brewnog.
That's good to know it's possible. So the load is wired in parallel to the supply and cranking up the load makes it harder to turn... What would I wire to the armature? (if anything)
What sort of generator would be best to use for this? I have at the moment an alternator off a ford sierra but may think about buying a DC generator if its better as I can get a through shaft one and measure the torque like I was saying. (or maybe measure current and work out power this way like you mentioned)
12K
14K
16K
23K
54K
