New Reply
Calculating the flow rate of water from a tap and on the surface of a water tank
Share Thread Thread Tools
Nov14-11, 12:15 PM   #1
I am really not sure how to go about this problem, can anybody please give me an indication on how I can start solving the problem?
An open rectangular water tank 1.2 m x 1.2 m x 2.6 m (height) is completely filled with water. As the tap at the bottom is opened, the flow rate from the tap at that moment is
2.0 x 10-4 m3 /s.
At this moment, calculate the
(i) the velocity of the water surface in the tank.
(ii) the velocity of the water coming out of the tap.
2. Relevant equations
3. The attempt at a solution
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Nov14-11, 12:30 PM   #2
The speed of the water surface in the tank is related to how much water that leaves the tank per second. What's the relation between the amount leaving the tank and the change in the height of water in the tank? The direction ("speed + direction" = velocity) is -y, or downwards, since the surface moves down.
Nov14-11, 12:47 PM   #3
Are you familiar with Bernoulli's equation?
Nov14-11, 01:13 PM   #4
Recognitions:
Homework Helper Homework Help
For (a) I would recommend a "related rates" calculus approach, if you are familiar with calculus (it is not really required here because the container is simply rectangular).
The idea is to write the rate you are looking for as the product of two related rates. You are given dV/dt and you want dh/dt so you would write
dh/dt = dV/dt*d?/d? [chain rule]
It is easy to find the ?/? expression with the chain rule and to work out its value from the formula for the volume of the tank.
For (b), one approach is to realize that the pressure at the tap is sufficient to push the water up to the height of the surface in the tank. That would be a conversion to a gravitational potential energy. In the case of the open tap, the same energy appears as kinetic energy. Begin with PE = KE for a mass m of water, cancel the m's and solve for v.
Nov14-11, 03:47 PM   #5
Ok, with regard to the related rates approach, I know how to apply it but I haven't it used in over a year so I need a bit of help with it. I've had a go at it, but I know i've done wrong or missed something along the way.
I have dh/dt=(dV/dt) x (dh/dV)
dV/dt = 2x10^-4 m^3/s
V=(h^2)*y
dV/dh = 2h
dh/dV = 1/2h
Sub-in dV/dt and dh/dV
dh/dt = 2x10^-4 x 1/2(1.2) = 8.33 x 10^-5 m/s
if dh/dV happened to equal 1/h^2 it would give the right answer but I can't get the mathematics to back it up at the moment.
I have had a try at the method delphi stated for the second part of the question, it got the correct answer, i'll post the working below:
PE=KE
mgh = 1/2m(v)^2
2gh = v^2
v = (2gh)^0.5
sub=in g=9.8 and h = 2.6m
v = (2(9.8)(2.6))^0.5 = 7.14 m/s
Nov14-11, 05:11 PM   #6
Recognitions:
dV/dh = 2h, dh/dV = 1/2h
can't be right; has wrong dimensions for one thing.
V = lwh so dV/dh = lw, dh/dV = 1/(lw)
Nov15-11, 08:21 AM   #7
PE=KE
mgh = 1/2m(v)^2
2gh = v^2
v = (2gh)^0.5
The above is the same as the Bernoulli's equation.
h1 + .5V1^2/g = h2 + .5V2^2/g
V1 term is negligible. h2 = 0.
V2 = (2 * g * h1)^.5
The Bernoulli equation can be applied to this reservoir situation even though the points of application are not on the same streamline.
Nov15-11, 12:58 PM   #8
Recognitions:
Thanks for that, Lawrence. I was under the impression that Bernoulli's equation was something very complex, but it now looks like it may come from a statement of conservation of energy.
New Reply
Thread Tools
Similar Threads for: Calculating the flow rate of water from a tap and on the surface of a water tank
Thread Forum Replies
Water flow rate through a slot at surface General Engineering 17
Calculating water flow rate to achieve lower skin temperature Mechanical Engineering 5
Water flow from Tank B to Tank C sizing questions Engineering Systems & Design 0
Water Flow Rate From A Tap Attached 2 A Tank General Physics 3
HELP! relationship between rate of flow of water and height of water column Introductory Physics Homework 1
