Can the radial component of the wave function satisfy the radial equation?
The radial component of the continuum electron wave function, represented as Rkl(r), satisfies the radial equation derived from quantum mechanics. The equation is expressed as: {\left[\frac{-\hbar }{2m}\frac{1}{r^2}\frac{\partial }{\partial r}\left(r^2\frac{\partial }{\partial r}\right)+\frac{\hbar ^2l(l+1)}{2m r^2}-\frac{Z e^2}{r}\right]R=E R}. The solution involves substituting R into the radial equation and simplifying using properties of confluent hypergeometric functions. The attempt to factor out R from the resulting expression indicates the complexity of the derivatives involved, particularly with the confluent hypergeometric function F.
  • Understanding of quantum mechanics, specifically the Schrödinger equation.
  • Familiarity with radial wave functions in quantum systems.
  • Knowledge of confluent hypergeometric functions and their properties.
  • Proficiency in calculus, particularly in taking derivatives of complex functions.
  • Study the properties of confluent hypergeometric functions in detail.
  • Learn how to solve second-order ordinary differential equations (ODEs) relevant to quantum mechanics.
  • Explore the derivation and application of the radial equation in quantum mechanics.
  • Investigate techniques for simplifying complex derivatives in wave functions.
Students and researchers in quantum mechanics, particularly those focusing on wave functions and radial equations, as well as physicists dealing with continuum electron states.
vst98
Show that radial components of the continuum electron wave function
satisfies the radial equation:
[itex]{\left[\frac{-\hbar }{2m}\frac{1}{r^2}\frac{\partial }{\partial r}\left(r^2\frac{\partial }{\partial r}\right)+\frac{\hbar ^2l(l+1)}{2m<br /> r^2}-\frac{Z e^2}{r}\right]R=E R}[/itex]
where:
E=(k*hbar)2/2m
R=Rkl(r)
so, the radial component R is given as:
[itex]{R_{\text{kl}}(r)=\frac{C_{\text{kl}}}{(2l+1)!}(2{kr})^l\text{Exp}[-\text{ikr}]*F(i/k+l+1,2l+1;2\text{ikr})}[/itex]
First I have rewritten R as:
Rkl(r)= C rl Exp[-ikr] F[i/k + l + 1,2l+1;2ikr]
where in C is everything that does not depend on r.
Great, I was thinking this will be pretty straightforward to show.
My reasoning was to insert R in the above radial equation, take those derivatives and at the end I will be able the factorize R out, so that I'm left with something like
HR=AR where A is the energy.
It did not work out like that :smile:
After taking the derivatives I'm left with a mess and I don't see how to factorize R out.
I mean, derivatives of Exp[-ikr] give me back the same function (multiplied by constant) so I can factorize that out but rl and F give me problems after derivation.
Also I was looking at the properties of these confluent hypergeometric functions F
and tried to adjust them back to original function but without success.
Can someone say whether I'm on the right track trying to solve the problem like that or
have I completely missed the point ?
Interesting problem. I would first try to relabel the confluent hypergeom function as u(r) and plug the solution into the original ODE. Then I'd be led to a second order ODE for u(r) which should have exactly the same solution with the confluent hypergeom function I'm given.
I'm not sure if I understood you well, but this is what I have tried:
Now R is given as:
Rkl(r)= C rl Exp[-ikr] u[r]
And a second order ODE that u[r] obeys is:
[itex]z\frac{d^{2}u}{dz^{^{2}}}+(b-z)\frac{du}{dz}-au=0[/itex]
where u is u[r]~F[a,b,z]=F[i/k+l+1,2l+1,2ikr]
So, I should insert R the into radial equation and with the help of this ODE for u[r] somehow simplify the result, right ?
Ok, I focused here only on the result I get when acting on R with this part of the radial equation
[itex]\frac{1}{r^{2}}\frac{\partial }{\partial r}(r^{2}\frac{\partial }{\partial r})[/itex]
the result after acting on R with this part is:
[itex]{c e^{-i k r} r^{-2+l} \left(\left(l+l^2-2 i k l r-k r (2 i+k r)\right) u[r]+r \left(2 (1+l-i k r) u'[r]+r u''[r]\right)\right)}[/itex]
Now, I have tried to bring this expression(or a part of it) to form of ODE for u[r].
But when I adjust the coefficient that multiplies u''[r] so that I have 2ikr*u''[r] , which is required by the ODE for u[r] then the coefficient for u'[r] is not in a proper form anymore.
And the rest of the equation is also of no help since these are the only u''[r] and u'[r] terms.
So I'm stuck again :)
  • · Replies 21 ·
  • · Replies 30 ·
