Investigating the Constancy of Light-Speed: A Call to Greater Knowledge
  • Context: Graduate
  • Thread starter Thread starter AtomSmasher
    Knowledge
The discussion revolves around the constancy of the speed of light and its implications for cosmology, particularly in light of claims that the speed of light may have changed over time. Participants explore various articles and studies that challenge conventional understandings of light speed and redshift measurements, raising questions about their reliability and the potential need for revisions in cosmological models.
  • One participant presents an article claiming that the speed of light has been decreasing over the last 250 years, suggesting that past measurements were consistently faster than current ones.
  • Another participant questions the measurability of any changes in light speed over the past 300 years, citing the limitations of early measurement techniques.
  • A participant references observations from a university study indicating that the fine structure constant may have been lower in the past, which could imply changes in the speed of light or electron charge over millions of years.
  • Concerns are raised about the implications of variable light speed on established cosmological models, particularly regarding redshift measurements and their role in supporting inflationary cosmology.
  • One participant expresses skepticism about the motivations behind the claims, noting that they are often used to support young or steady state universe theories.
Participants exhibit disagreement regarding the constancy of light speed and the interpretation of redshift data. Some propose that light speed may have changed, while others argue that such changes would not be measurable and question the validity of the claims made in the articles referenced.
Limitations in early measurement accuracy are noted, as well as the potential for varying interpretations of redshift data. The discussion does not resolve these uncertainties and remains open to multiple viewpoints.
AtomSmasher
I'm sure this forum is frequented by people claiming to have proven or disproven aspects of relativity. In this case I am appealing to those with greater knowledge than mine, specifically in regards to the constancy of light-speed. The case has been made to me that the speed of light is not constant, and has changed measurably over the last 250 years. Essentially, I have been provided a link by a friend and co-worker which, to the lay-person (myself), seems to present a convincing case that the speed of light is variable.
The article, (http://www.setterfield.org/history.htm#before1941 by Barry Setterfield), contains compiled data from nearly 300 years of light-speed measurements that indicate that the speed of light is slowing down. The article claims that measurements of light in the past have always shown it to be faster than it is today, without exception. Obviously a changing speed of light would call into question a great many things, in particular, the use of light as a constant for measuring speed and distance.
Following that up was another article calling into question the gradual redshift of regressing celestial light sources:(On the Quantization of the Red-Shifted Light from Distant Galaxies by Mark Stewart), which cites the observations of rotating galaxies as contradictory evidence of a gradual redshift curve, and therefore calls into question the dependability of redshift as a measurer of speed and distance in regressing objects which, as I understand, is an important support for inflationary cosmology.
Here is a quote from the article which provides apparently specific information regarding unusual redshift measurements in gravitationally bound galaxies:
"Two galaxies physically associated with one another offer the ideal test for redshift quantization; ...
...If we observe many pairs covering a wide range of viewing angles and orbital geometries, the expected distribution of redshift differences should be a smooth curve. In other words, if redshift is solely a Doppler effect, then the differences between the measured values for members of pairs should show no jumps.
But this is not the situation at all. In various analyses the differences in redshift between pairs of galaxies tend to be quantized rather than continuously distributed. The redshift differences bunch up near multiples of 72 km per second. Initial tests of this result were carried out using available visible-light spectra, but these data were not sufficiently accurate to confirm the discovery with confidence. All that changed in 1980 when Steven Peterson, using telescopes at the National Radio Astronomy Observatory and Arecibo, published a radio survey of binary galaxies made in the 21-cm emission of neutral hydrogen.
Red shift differences between pairs group around 72, 144, and 216 km per second. Probability theory tells us that there are only a few chances in a thousand that such clumping is accidental. In 1982 an updated study of radio pairs and a review of close visible pairs demonstrated this same periodic pattern at similarly high significance levels.
Radio astronomers have examined groups of galaxies as well as pairs. There is no reason why the quantization should not apply to larger collections of galaxies, so redshift differentials within small groups were collected and analyzed. Again a strongly periodic pattern was confirmed.
He [Mark Stewart] provides further evidence collected from observations of dwarf irregular galaxies and draws the conclusion: "Current cosmological models cannot explain this grouping of galaxy redshifts around discrete values across the breadth of the universe. As further data are amassed the discrepancies from the conventional picture will only worsen. If so, dramatic changes in our concepts of large-scale gravitation, the origin and "evolution" of galaxies, and the entire formulation of cosmology would be required."
With my limited personal knowledge of modern physics and cosmology I cannot myself determine the truth of this article. If any of you can point out the fallacies, support the conclusions, or otherwise provide articles or information that might confirm or contradict the evidence or conclusions of this article and others claiming errancy in redshift interpretation I am interested and grateful for your time.
As many of you have guessed, this article is being used as a support for a young or steady state universe in a likely attempt to reconcile the contradictory evidence of (old universe) inflationary cosmology with biblical time frames (in a word: Creationism). I don't often consider arguments that start with a conclusion and work backwards, but in all fairness one must be open to contrary beliefs and therefore I am giving this argument real consideration.
I immediately returned to my college Astronomy textbook for answers. I found plenty of evidence to support a gradual redshift, but it did not address this specific issue -- leading me to believe that the authors did not deem it worthy of consideration, simply overlooked it, or intentionally ignored it (supressed by the global scientific conspiracy [j/k]:)) I came across this site while looking for more information, I am hoping some of you may have addressed this before or have knowledge in this area. Any help is very much appreciated.
-Galen
Science news on Phys.org
There is speculation of a changing speed of light but the difference would not be measurable over the past 300 years. The accuracy of the initial light speed tests simply wasn't good enough to measure it. Michelson's measurement 120 or so years ago was probably the first reasonably accurate one.
Question: what are the comparitve results since 12o years?
I read that in 2002, in one university in Sydney, some scientist made observations in an ancient object in the sky (I don't know what kind of object) and they saw that the fine structure constant could be lower than today various millions of years ago. This would imply that the charge of electron or "c" have changed. They supposed the change was due "c" and was higher than today various millions of years ago.
Sorry I don't have any link.
  • · Replies 42 ·
  • · Replies 52 ·
  • · Replies 0 ·
