Internal structure <->property?
  • Thread starter Thread starter ballballisicious
    Internal Structure
The discussion focuses on the relationship between the internal structure of steel and its properties, such as malleability and hardness. Key references include ASM Specialty Handbooks on "Carbon and Alloy Steels" and "Stainless Steels," which provide detailed tables of steel compositions and their corresponding properties. The conversation highlights various steel types, including austenitic, ferritic, and martensitic steels, and their unique characteristics. Additionally, resources such as metals.about.com and academic texts on physical metallurgy are recommended for further exploration.
  • Understanding of steel types: austenitic, ferritic, and martensitic steels
  • Familiarity with ASM Specialty Handbooks
  • Basic knowledge of physical metallurgy principles
  • Awareness of precipitation hardening processes
  • Research the effects of alloying elements on steel properties
  • Learn about the heat treatment processes for martensitic steels
  • Explore the applications of duplex stainless steels in engineering
  • Investigate the principles of precipitation hardening in steel
Materials scientists, metallurgists, and engineers involved in steel production and application will benefit from this discussion, particularly those seeking to understand the correlation between steel's internal structure and its mechanical properties.
ballballisicious
internal structure <-->property?!
can anyone suggest some link relating the internal structure of steel (like crystal arrangement such kind of thing) to their property like malleability, hardness etc.
it's hard to get information from search engine.
(it'd be better if it talks about the common steel)
any help will be appreciated :smile:
See my last post on your thread, "the shock absorbing ability of steel".
https://www.physicsforums.com/showthread.php?t=54157&page=2
ASM publishes several Specialty Handbooks, including one on "Carbon and Alloy Steels" and another on "Stainless Steels". See if your or other departments have it, or the university library; otherwise have them order it.
Both books have tables of composition and properties of a wide variety of steels, as well as a discussion of the effects of composition on properties.
Meanwhile, this can help get you started (from metals.about.com):
http://metals.about.com/library/bldef-Austenitic-Steels.htm
"Definition: Steels containing high percentages of certain alloying elements such as manganese and nickel which are austenitic at room temperature and cannot be hardened by normal heat-treatment but do work harden. They are also non-magnetic. Typical examples of austenitic steels include the 18/8 stainless steels and 14% manganese steel. The 300 Series (e.g. SS302, 304, 308, 316, 321, 347) represent a large portion of austenitic steels."
Ferritic Steels
"Definition: A term usually applied to a group of stainless steels with a chromium content in the range of 12- 18o and whose structure consists largely of ferrite. Such steels possesses good ductility and are easily worked but do not respond to any hardening or tempering processes. Types of applications include automotive trim and architectural cladding."
http://metals.about.com/library/bldef-Martensitic-Stainless-Steels.htm
"Definition: These grades (SS400 Series) of stainless steels have chromium in the range of 11% to 17% as the sole major alloying addition. This is the same as the ferritic grades. However, carbon is added in amounts from 0.10 % to 0.65% to radically change the behavior of the martensitic alloys. The high carbon enables the material to be hardened by heat treatment."
http://metals.about.com/library/bldef-Duplex.htm
"Definition: A category of stainless steel with high amounts of chromium and moderate nickel content. The duplex class is so named because it is a mixture of austenitic (chromium-nickel stainless class) and ferritic (plain chromium stainless category) structures. This combination was originated to offer more strength than either of those stainless steels. Duplex stainless steels provide high resistance to stress corrosion cracking (formation of cracks caused by a combination of corrosion and stress) and are suitable for heat exchangers, desalination plants, and marine applications."
Also, look on Google for Precipitation Hardening (and Precipitation Hardened Steels), Nimonic,
Overview of stainless steels - http://www.outokumpu.com/pages/Page____5814.aspx
Austenitic Manganese Steels
Austenitic Steels
In general - http://www.key-to-metals.com/Articles.htm
Normally, the physical metallurgy and heat treatment of steels is (at least) a one semester course.
Astronuc has provided a good set of references for Alloy steels (like SS) and ASM handbooks are typically available at a good (university) library. If I recall correctly, the texts I used for Physical Metallurgy were Reed-Hill and Smallman.
There's also a pretty good summary http://www.tf.uni-kiel.de/matwis/matv/pdf/met_17y.pdf
