Power transmission and dielectric constant
The discussion focuses on calculating the reflectivity of a system comprising ice on top of water, utilizing the dielectric constants of both materials. The formula for reflectivity is established as rho = ((sqrt(dielectric constant)-1)/(sqrt(dielectric constant)+1))^2. The conversation emphasizes the importance of considering multiple reflections at the interfaces and the phase shift due to varying ice thickness. Ultimately, the solution involves summing an infinite series of reflections, with the phase change represented as e^(i*k*d).
  • Understanding of dielectric constants and their application in optics
  • Knowledge of reflection and transmission at media interfaces
  • Familiarity with complex exponentials and their role in wave physics
  • Basic principles of light behavior at normal incidence
  • Research the derivation of Fresnel equations for multiple media interfaces
  • Study the concept of infinite series in optics and its applications
  • Explore the effects of phase shifts on light reflection and transmission
  • Learn about the impact of varying thickness in layered materials on optical properties
Physicists, optical engineers, and anyone involved in the study of light behavior in layered media, particularly in applications related to ice and water interfaces.
cesarsalad
How do I find the reflectivity of a combination of ice on top of water(infinite half-space) as a function of the thickness of ice? I know how to find it for each material, it's just rho = ((root(dielectric constant)-1)/(root(dielectric constant)+1) )^2. I'm given dielectric constants for both. I'm pretty sure we have to calculate the emissivity of the top layer of ice, the emissivity of the underlying water, combine them together somehow, and reflectivity = 1 - emissivity.
There is no attenuation, and the thickness varies from 0 to the wavelength. So it's related to the phase shift somehow.
But I don't know how to calculate how much power goes from the sun, let's say, through the ice to the water and how it's related to the thickness of the ice. Does anyone know where I can find such an equation?
First of all, is the light at some angle - important for determining reflectance (and transmission).
Think about the fact that there are 3 media, and so 2 interfaces, 1 and 2.
At media interface 1, the incident light, I, is split. Say the amount that is reflected is Ir1 = r1I, so the transmitted light intensity It1 = (1-r1)I.
Now some of that light is reflected at the ice-water interface, Ir2=r2It1= r2 (1-r1)I.
OK, but now the light reflected from the 2nd interface must pass through interface 1 again. So work out that equation, and think about the fact that remaining light is going from water to air, rather than air to water.
Then can you write r1 and r2 in terms of the dielectric properties (and thickness of ice as applicable)?
What light that emerges from the ice can be added to the reflected light to get the total intensity.
Hi,
Thank you
There are going to be an infinite number of reflections. These reflections add up as an infinite series. For example, the total reflection is the reflection from the ice + one that went through the layer once + one that went through the layer twice + etc. What I'm having trouble figuring out is just how.. I know the layer thickness changes the phase, but how, and what does this have to do with the total reflectivitiy? btw, the wave is incident straight down (normal incidence)
EDIT: nevermind.. i figured it out. the phase changes like e^(i*k*d)
10K
