| New Reply |
Pendulum/Simple Harmonic Motion, what is its energy of motion? |
Share Thread | Thread Tools |
| Nov16-11, 02:09 AM | #1 |
A 1.2 kg mass attached to a spring oscillates with an amplitude of 5.1 cm and a frequency of 2.1 Hz. What is its energy of motion?
I just have to use KE=1/2mv^2 right? do I have to involve the amplitude? |
| Nov16-11, 02:15 AM | #2 |
In SHM the KE is continually varying. So you are asking for the MAX KE, right?
| Nov16-11, 02:28 AM | #3 |
I just need the energy of motion, so i guess that means KE max?
| Nov16-11, 02:50 AM | #4 |
The KE max will be the total energy of the motion.
You are correct to use KE=1/2mv^2 but you need an expression for vmax in simple harmonic motion. You will need to find the spring constant (stiffness) and use this to find the max velocity. Do you know these equations? |
| Nov16-11, 02:52 AM | #5 |
What is the max linear velocity in SHM?
| Nov16-11, 03:02 AM | #6 |
Vmax=Aw
| Nov16-11, 03:04 AM | #7 |
Then you can find max ke = (1/2)mv^2 and use v = Aw
| Nov16-11, 03:15 AM | #8 |
thank you sooo muuuch!!!!! :D
| Nov16-11, 03:19 AM | #9 |
Recognitions:
| Nov16-11, 03:27 AM | #10 |
the problem doesnt say
| Nov16-11, 03:55 AM | #11 |
Recognitions:
The total of them at any time will be constant. That might be what is meant by the energy of the motion. Even if the situation is horizontal [so no change in gravitational potential energy] there is a steady interchange between elastic potential energy and kinetic energy. |
| New Reply |
| Tags |
| pendulum, shm |
| Thread Tools | |
Similar Threads for: Pendulum/Simple Harmonic Motion, what is its energy of motion?
| Simple harmonic motion of a pendulum | Introductory Physics Homework | 1 | ||
| Simple Harmonic Motion: Pendulum | Introductory Physics Homework | 1 | ||
| Pendulum Motion (Simple Harmonic Motion) | Introductory Physics Homework | 0 | ||
| Pendulum in Simple Harmonic Motion | Introductory Physics Homework | 3 | ||
| Simple Harmonic Motion of a Pendulum | Introductory Physics Homework | 4 | ||
