Why is my calculated atmospheric pressure different from the given value?
  • Thread starter Thread starter timon00
    Fluids
The discussion revolves around calculating atmospheric pressure and manometric pressure in fluid dynamics contexts. The original poster presents two problems: one involving the reduction of barometric height due to a storm and another concerning the pressure required for water to exit a fire extinguisher at a specified speed.
  • Participants explore the relationship between pressure, height, and velocity in fluid dynamics. There is a focus on deriving pressure equations based on energy considerations. Questions arise regarding discrepancies in calculated values and the reasoning behind certain multiplications in the formulas used.
Some participants have provided calculations and reasoning, while others seek clarification on the methods used. There is an ongoing exploration of the problem, with participants questioning assumptions and interpretations of the equations involved.
Participants note potential confusion regarding the application of formulas and the interpretation of the problem statements. There is an acknowledgment of differing answers based on calculation methods, highlighting the need for careful consideration of each term in the equations.
timon00
16. The normal atmosphercic pressure is 1.013 x 10^5. A storm causes that the height of the barometer of mercury reduce 20.0 mm form the normal height. What is the atmosferic preasurre ? ( the density of mercury is 13.59 g/cm3
50. Out of a fire extingisher comes out water under air presurre. What manometric pressure is required in the tank for the water burst to have a speed of 30 m/s when the water level is 0.5 m below the water pump.
as hard as i try i really can't solve is problems can anyone help me?
i got the first one , can anyone help me with the other one?
It is not entirely clear on the question but it seems that the air pressure has to lift the water .5 m and send it out at 30 m/sec.
Think of pressure as an energy density (energy/unit volume):
[tex]P = \frac{\delta E}{\delta V}[/tex]
In order to lift an element [itex]\delta m = \rho \delta v[/itex] of water h = .5 m. and accelerate it to v = 30 m/sec energy of:
[tex]\delta E = \delta mgh + \frac{1}{2}\delta mv^2[/tex]
is required. So an energy density of:
[tex]\frac{\delta E}{\delta V} = \rho gh + \frac{1}{2}\rho v^2 = P[/tex]
[tex]P = \rho (gh + \frac{1}{2}v^2)[/tex]
[tex]P = 10^3 (9.8 \times .5 + .5 \times 900)[/tex]
[tex]P = 4.55 \times 10^2 KPa[/tex] or about 4.55 atm. (4.55 bars)
AM
thanks andrew but i have another question
so i did P = 10^3(9.8*0.5 +900*0.5) = and it gives me another answer diffrent that yours it gives me 4.55 x 10^5 half of what you got , why did u multiply it by two ??
Just forgot to multiply by the .5. See edited reply above
AM
10K
