Thermodynamics - ideal gas properties
by johnsmith456
Tags: ideal, properties, thermodynamics
johnsmith456
johnsmith456 is offline
#1
Nov20-11, 06:37 AM
P: 5
Hey guys,
I'm working on calculating the enthalpy, entropy and internal energy of substances. treating them as an ideal gas. I wonder if I could be pointed in the right direction with some calculations.
Enthalpy change:
h2-h1=∫cp dT+ ∫[v-T(∂v/∂T)P]dP
At ideal gas the pressure integral goes to zero.
So we have just the integral of Cp with respect to T.
All correct so far?
Its with the entropy and internal energy where I get confused.
ds = (Cp)dT - (∂v/∂T)P dP
is there a way to simplify this further at ideal gas to make it easily calculated ?
I guess internal energy can be calculated from h using h = u + Pv.
Thanks very much
Look forward to any replies.
2. Relevant equations
3. The attempt at a solution
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
Andrew Mason
Andrew Mason is offline
#2
Nov20-11, 08:15 AM
Sci Advisor
HW Helper
P: 6,564
Quote Quote by johnsmith456 View Post
Enthalpy change:
I am not sure how you get this. If H = U + PV, then dH = dU + PdV + VdP and ΔH = ΔU + ∫PdV + ∫VdP = ΔQ + ∫VdP
So, if pressure is constant, ∫VdP = 0, so ΔH = ΔQ = ∫CpdT
All correct so far?
Not in general. This is true only if P is constant.
Since U and PV are state functions, ΔU and Δ(PV) are independent of the path between two states so they are the same whether the path is reversible or irreversible. For a reversible path, ΔH = ΔQ + ∫VdP = ∫TdS + ∫VdP. Consequently, this must be true for all paths.
So you can use: dH = TdS + VdP
AM
Register to reply
Related Discussions
Specific heats relating to ideal gas properties? Classical Physics 1
Thermodynamic properties of ideal gases Classical Physics 7
[Thermodynamics] Ideal Gas Properties of Air Classical Physics 4
Thermodynamics/Ideal gas Introductory Physics Homework 2
