Work required to pump water out of a conical tank
by jollyrancher
Tags: conical, pump, required, tank, water, work
jollyrancher
jollyrancher is offline
#1
Nov22-11, 04:05 AM
P: 1
Find the work required to empty a 10m high conical tank with a radius at the top of 4m by pumping the water out the top of the tank. The water level is 2m below the top of the tank.
2. Relevant equations
[itex]\pi r^2[/itex]
Similar triangles
3. The attempt at a solution
General formula for the radius:
[itex]\frac{4}{10} = \frac{r}{(10-x)}[/itex] where x = distance from the top of the tank.
[itex]r = \frac{2}{5}(10-x)[/itex]
Therefore, the volume of any given slice [itex]= \pi(\frac{2}{5}(10-x))^2\Delta x[/itex]
This is where I get a bit confused. What do I need to multiply my volume formula by when I integrate from x = 2 to x = 10?
Also, after I have multiplied my volume by the whatever I need to (distance?) and integrated between 2 and 10, have I pumped the water out the top of the barrel or only to the top of the water level? Do I need to add +2m to something somewhere?
Thanks.
Phys.Org News Partner Science news on Phys.org
Lemurs match scent of a friend to sound of her voice
Repeated self-healing now possible in composite materials
'Heartbleed' fix may slow Web performance
BruceW
BruceW is offline
#2
Nov22-11, 03:56 PM
HW Helper
BruceW's Avatar
P: 3,337
Its actually a tricky question, which is maybe why there are no replies yet. You have the right answer for the radius of the cone as a function of x. (As long as you remember the units you are using, since strictly the 10 should be 10m).
And you have correctly given the volume of a small slice. And you are right, you need to multiply by x before you do the integration. (Or maybe you should multiply by -x, since your coordinate system is upside-down). Also, you need to multiply by the density and g to get the correct units for energy.
So once you've done this, you will have the GPE of the water before it is pumped. You can then work out what the GPE would be if all the water was at the top of the barrel (easy, since it is all at the same height). Then subtract one GPE by the other GPE to get the change in GPE.
Register to reply
Related Discussions
Revolving a tank around the y axis: Work needed to pump water Calculus & Beyond Homework 2
Work required to pump water out of conical tank Calculus & Beyond Homework 4
Calculate the work to pump water out of tank Introductory Physics Homework 1
Work needed to pump water out of spherical tank Calculus & Beyond Homework 3
Optimization question - water in a conical tank Calculus & Beyond Homework 1
