Point load Vs Distributed loads
The classification of loads in structural engineering is determined by the relationship between the load's contact area and the total size of the supporting structure. A load can be classified as a point load if its contact area is significantly smaller than the beam or plate it acts upon. For instance, a 30-foot long I-Beam with a 1-foot lifting lug is modeled as a point load for efficiency and conservative analysis. Conversely, a 20,000 lb liquid-filled vessel with saddles on beams warrants classification as a distributed load for accurate structural analysis.
  • Understanding of structural load classifications
  • Familiarity with I-Beam properties and applications
  • Knowledge of load analysis techniques
  • Basic principles of beam and plate mechanics
  • Research the differences between point loads and distributed loads in structural analysis
  • Study the effects of load distribution on I-Beam performance
  • Explore software tools for load analysis, such as SAP2000 or ANSYS
  • Learn about load combinations and their implications in structural design
Structural engineers, civil engineering students, and professionals involved in load analysis and beam design will benefit from this discussion.
koolraj09
Hi all.
Do we have a boundary (for classification) as to when a load can be called a point load or a distributed load?
Thanks.
For practical purposes, I look at the region the load contacts compared to the total size of the beam or plate.
For example, suppose you have a 30 foot long I-Beam with a lifting lug that is 1 foot long. I would model the lifting lug as a point load since it is quicker to analyze and conservative and the difference in the result is not very much.
On the other hand, suppose you have a 20,000 lb liquid filled vessel with its saddles sitting on beams. In this case, a distributed load is justified for analyzing the supporting beams.
9K
