Integrate Spiral on YZ Plane | Location X | Need Help with Problem
  • Context: Undergrad
  • Thread starter Thread starter starbaj12
    Spiral
The discussion revolves around the integration of a spiral defined on the yz plane, with considerations of its properties and the mathematical approaches to perform the integration. Participants explore various aspects of the problem, including parameterization, line integrals, and the geometric interpretation of the spiral.
  • One participant seeks to integrate a spiral on the yz plane, questioning the relevance of a specific location on the x-axis.
  • Another participant suggests using a parameterization of the curve to calculate its length, proposing a formula involving derivatives.
  • A participant introduces the concept of "alpha," referring to the angle subtended by a radius at a point of observation on the x-axis.
  • Concerns are raised about the feasibility of integrating a spiral, with one participant stating that integration applies to functions rather than geometric shapes.
  • Another participant questions the use of the term "subtend," arguing that a single line cannot subtend an angle, and seeks clarification on the terminology used.
  • A participant expresses frustration with mathematical language and terminology, suggesting that it should be more accessible to non-mathematicians.
  • One participant clarifies that the spiral has a center in the yzx axis and suggests using polar coordinates for the integration, while also needing to find a vector field along the x-axis.
  • A suggestion is made to parameterize the spiral similar to common examples in calculus, with a reference to line integrals in three-dimensional space.
  • Another participant emphasizes the need for careful integration, noting that it must be done in segments where the length is well-defined.
Participants express differing views on the integration of the spiral, with some questioning the validity of the approach and others providing mathematical methods. There is no consensus on the correct interpretation or method for integration.
Participants highlight potential misunderstandings regarding terminology and the mathematical concepts involved, indicating a need for clearer communication. There are also unresolved questions about the specific properties of the spiral and the integration process.
starbaj12
There is a spiral but it is just on the yz plane (no length to it) I need to integrate it. And I'm at a location x on the axis if it matters.
Thanks
What do you want to calculate? its lenght? if so, let [itex]M(t)[/itex] be your curve, as long as [itex]M'(t) \ne 0[/itex] then
[tex]Length[M]=\int_{t_0}^{t_1} \sqrt{\dot{x}^2+\dot{y}^2+\dot{z}^2}ds[/tex]
alpha; which is the angle subtended by a radius at the point of observation (x).
I'm sorry but I can't make heads or tails of this.
"There is a spiral but it is just on the yz plane (no length to it) I need to integrate it."
?? You can't integrate a spiral, you can only integrate a function.
"alpha; which is the angle subtended by a radius at the point of observation (x)."
What about alpha? A single line does not "subtend" an angle. And what is the "point of observation"?
What does "subtend " mean ? Can't you mathematicians puy it in words ordinary people can understand . Also "leght " is spelled "length". The expression is "head or tail "for a single event not "heads and tails ". You mathematicians are so precise in everything except the lagauge used to express your ideas .
Sorry "put" not puy (slip of the finger )
The spiral has a center in the yzx axis (it is like a coil but flat so the radius gets bigger) You can do this by polar coordinates (I was told), but I do not know how. I need to find a vector field that is directed along the x axis. And alpha is the angle subtended by a radius at the point on x.
He used "subtend" perfectlly...if it were a helix, but its a spiral, so there is no angle. The rest of your complaint is about typos and dialects, which is pointless to get mad about.
starbaj12, I think you'll need to be more specific in your request for help.
-Burg
Line integrals of three space
You can find it by parameterizing the curve. Spirals are pretty easy to parameterize and would be similar to: x=cos(t) y=sin(t) z=t. Then you can take the integral from start to finish of f(x(t),y(t))|ds|dt. You can find this by looking in the index of any calculus book under line integrals in 3-space or something similar. This isn't usually done until Calculus III, so it would be towards the back of the book.
also, as halls of ivy just said, you can't go integrating blindly, you need to do it by pieces (where the length is well defined, [itex]M'(t)\ne 0[/itex])
  • · Replies 17 ·
11K
  • · Replies 16 ·
