Convergence of Series to |x|: A Calculus Approach
  • Thread starter Thread starter erogard
    Converging Series
The discussion revolves around proving the uniform convergence of a sequence of functions \( P_n(x) \) to \( |x| \) on the interval \([-1, 1]\). The original poster presents a recursive definition for \( P_n(x) \) and references a hint from Rudin involving an identity that relates \( |x| \) and \( P_n(x) \).
  • Participants explore the implications of the recursive definition and the provided identity. There are attempts to show inequalities involving \( P_n(x) \) and \( |x| \), as well as questions about the validity of certain steps in the proof process. Some participants express uncertainty about specific inductive steps and the application of calculus to find maximum values.
The discussion is active, with participants sharing their progress and challenges. Some have successfully demonstrated certain inequalities, while others are still working through the details of the proof. There is a collaborative effort to clarify steps and explore different methods, including the use of calculus to analyze the behavior of the sequence.
Participants are working under the assumption that \( |x| \) is constrained to the interval \([-1, 1]\), which influences the inequalities being discussed. There is also mention of potential typos in the original problem statement, which has been clarified by participants.
erogard
Hi everyone,
I need to show that [tex]\lim_{n\to\infty}P_n(x) = |x|[/tex] uniformly on [tex][-1,1][/tex]
if we define [tex]P_0 = 0[/tex] & [tex]P_{n+1} = P_n(x) + \frac{x^2 - P_n^2(x)}{2}[/tex]
Rudin gives the following hint: use the identity [tex]|x| - P_{n+1}(x) = \left( |x| - P_n(x) \right) \left( 1 - \frac{|x|+P_n(x)}{2} \right)[/tex]
to show that
[tex]0 \leq P_n(x) \leq P_{n+1}(x) \leq |x|[/tex]
if [tex]|x| \leq 1[/tex]
and that [tex]|x|-P_n(x) \leq |x| \left( 1-\frac{|x|}{2} \right)^n < \frac{2}{n+1}[/tex]
if [tex]|x| \leq 1[/tex] (though I think that's a typo, he probably meant greater than or equal)
From there I could readily show that the difference |x| - P_n goes to 0 when n goes to infinity.
But I'm not sure how to go about this problem. I would use recursion on n, and I was advised to consider the fact that the arithmetic average is always less or = than the highest term that enters the average (dunno how to use this fact here).
Any help would be appreciated.
It's not a typo. You are always working with x in [-1,1].
So, where exactly are you stuck?? Can you show that "idenitity"? Can you show that
[tex]0\leq P_n(x)\leq P_{n+1}(x)\leq |x|[/tex]
Can you show that
[tex]|x|-P_n(x)\leq \frac{2}{n+1}[/tex]
Which of these three doesn't work?
Ok well I was able to show that [tex]P_n(x) \leq |x|[/tex] by recursion on n for all natural numbers n by using the given identity and the fact about the average that I mentioned. But not that P_n is less than P_n+1 yet, couldn't get the inductive step to work out the way I want (my inductive hypothesis being that there exist a natural number k such that P_k < P_k+1 and from there I'm trying to show that P_k+1 < P_k+2.
Also, my bad regarding the inequality with |x|, it's obv not a typo considering the interval we're working on.
erogard said:
Ok well I was able to show that [tex]P_n(x) \leq |x|[/tex] by recursion on n for all natural numbers n by using the given identity and the fact about the average that I mentioned. But not that P_n is less than P_n+1 yet, couldn't get the inductive step to work out.
OK, so you need to show that
[tex]P_n(x)\leq P_{n+1}(x)[/tex]
Writing out [itex]P_{n+1}(x)[/itex], you get that you need to show
[tex]P_n(x)\leq P_n(x)+\frac{x^2-P_n^2(x)}{2}.[/tex]
So, what can you do next??
Oh well that follows directly from the fact that [tex]P_n(x) \leq |x|[/tex] Ok thanks a lot. I will try to prove the second inequality now.
Still can't get the second part. Tried something with the binomial expansion to show that
[tex]|x| \left( 1-\frac{|x|}{2} \right)^n < \frac{2}{n+1}[/tex]
but I can't relate my result to 2/(n+1).
Also would you use recursion to show that [tex]|x|-P_n(x) \leq |x| \left( 1-\frac{|x|}{2} \right)^n[/tex] ?
EDIT: Just got the above inequality, I will try again the one with 2/(n+1).
Why don't you try to find the maximum of
[tex]|x| \left( 1-\frac{|x|}{2} \right)^n[/tex]
by calculus?? Calculate the derivative and see what the critical points are (= where the derivative is 0 or does not exist)
Got it, thanks a lot for your help.
  • · Replies 105 ·
13K
